JamesWilson
1275 Engine with twin SUs that doesn't run.
Ws running fine, then sat for a while and developed problems- would idle OK but wouldn't run under load.
After much aggravation and puzzlement, I found water had gotten into the fuel tank. I drained that, flushed out the fuel lines and mopped the old fuel out of the float bowls. Refilled with fresh fuel.
But it still doesn't run. Electrics all OK- sorted those out before discovering the real problem. Good fuel pump and flow.
I suspect some grit from the fuel tank has gotten into the carb(s)and is blocking their internal passages, despite having a filter between tank and pump.
The fuel bowls fill OK.
Is it possible to see the fuel being sprayed when the engine is cranked to start? I see none, but don't know if that's normal.
Is there an easy way to clean these on the car? I'm not enthusiastic about pulling them off, though I've resigned myself to that....
Any advice would be appreciated greatly.
