BJ8 versus BT7 Shroud
J Eade
Member
I have a 64 phase 1 BJ8. Was the front shroud on this model the same as a BT7? Will the grill on my BJ8 fit the opening of the BT7 shroud? Thanks.
Keoke
J Eade, I think the only significant change in the front shrowd came with the phase 11 BJ8 cars.---Keoke
stevebn2bj7
No, the shrouds are completely different. The difference in in the windshield and scuttle top area. The BJ8 windshield goes much further forward than the BT7 and the corner area by the door tops has a completely different shape. The front of the shroud is identical though.
BlueRidge1
Didn't bt7's have 2 front parking lamps and bj8
have 4? I think the bt7 is the same as a bn7 and a bn6 and possibly a bn4,but differt than bj7 and bj8. I Think the grill would work. Bob
shorn
Correct, almost. Early BJ8's had only two parking lamps. The BN4, 6, 7, & BT7 are the same. BJ7 and early BJ8 are the same and the BJ8 from 76138 is different from the BJ7 and early 8.
John_Progess
J Eade,
I am restoring a Phase 1 BJ8 also. Would you happen to have the console extension with the hinged lid, mine is missing and I am looking for dimensions,pictures so I can make one. Thanks and have a good day!
John
vette
Hi "J", I think your question is about whether the grills will interchange. I honestly don't know, but there is a good chance that they will. But the shrouds did have differences. Most noticeably is the lights and the bossing out of the sheetmetal for the lights. My BJ7 has two lights on each side,(parking and turnsignal), Many BJ7's only have the one light,as the previous cars, but my lights are not as big around as on the BJ8. They are the smaller size with glass Lucas lens instead of plastic. It is what was called the European version. /ubbthreads/images/graemlins/cheers.gif
shorn
John,
On my phase 1 hinged cubby box, it is about 10 3/4 inches long, hinged at the back. It is the same width as the rest of the counsel, about 4 7/8. Measurements are outer dimensions and include the vinyl covering. The top is padded, and sort of semi-circular shaped. the center of the padded top measures about 1 3/4 inch thick. There are two about 1 inch crome hinges at the back, 4 screws in each hinge. The closing mech is just a magnet that clings to a piece of metal at the front of the box. Having trouble posting a picture, but I will email you a couple.
J
J Eade
Member
Thanks to all for their responses. Here's the history behind my question. When I bought my BJ8, the grill surround was missing. Being excited to finally have my dream car, I figured I could obtain the surround and bolt it in. Well, I did find an NOS surround, but the shape of the oval in my shroud does not match the surround. Additionally, the arc (front to rear shape) of the two components off as well. This led to my thinking that the car has an "incorrect" shroud. I have trying to source a used Phase 1 shroud, but so far no luck. Would I better of going with some of the replacement panels and having a body shop fit the surround? Sounds as though I am in for some body work no matter what.
Thanks. J.
shorn
Hi J.,
I had my phase 1 BJ8 repainted last year. In order to save a few $'s, I took off all the bright work including the grill, and the 2 piece surround. Two months later, when I received the car back from the painter, I was sure the grill surround wasn't going to fit. I couldn't remember exactly how I removed it, and the last thing I wanted to do was scratch the new paint. Well, ultimately, it did fit just fine. Note that the same grill surround fits the Bn7/BT7 from 13751, and the BJ7 and BJ8. Earlier models had the earlier grill. I think I would find someone with a BJ8 and measure/compare their grill opening with yours. If it is the same, perhaps the fitment of the grill surround will become apparent.
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
