BJ8 foot well panel photo request
AUSMHLY
64BJ8. Hi all,
I am getting ready to re-install my two inside foot well panels on my BJ8. My left and right panels are each is held in by 3 screws, as marked with green tape, see attached photo. The PO wraped the leading edge of each around and the metal edge, then glued it. Then the Bristleflex will press over that edge.
I have seen other cars with more screws used in those panels. For instance, screws used in the middle of the panels too.
Being I am reinstalling per what the PO did, is mine correct? If not, could someone post a photo showing how many screws and where they should be. Also, does the leading edge get glued around the leading edge?
Thank you, Roger
Velox
Hi Roger, saw your post, hope this doesn't add to the confusion as mine 66BJ8 may be all wrong but thought I'd at least provide a sample...first is driver's side lower
then driver's side upper
then passenger side lower
and finally pass side upper
Anyway good luck with your installation /ubbthreads/images/graemlins/cheers.gif
AUSMHLY
AUSMHLY
Hi Velox,
I was just about to write, that this is the first post of mine, where no on commented.
Thank you for taking the time to attach those pictures. Very nice.
And your spot on, yes you have added to my confusion. In a good way of course.
Anyone: what's the answer about how many screws and if they are only on the edges, also in the middle, if so where?
As you know, this is a learn as I go. I appreciate all the help I get here along the way. Cheers, Roger
shorn
Hi Roger,
I just replaced the kick (foot well) panels on my ph 1 BJ8. At the top of each panel a bolt passes through the side windshield frame and through the very top of the kick panel, into the instrument panel. I had to make that hole in each kick panel. Mine is a Moss kit. There are one or two holes in the fiberboard under that for the other windshield frame nuts to fit into the kick panels, but those bolts do not penetrate the foam or vinyl. On the driver's kick panel, there were no screws at all. On the passenger kick panel, I had just two screws, centered above and below the cut out. My kick panels were original.
Velox
[ QUOTE ]
[/ QUOTE ]
Well that matches up with what I found, there are no screws I could see on my driver's side panel either /ubbthreads/images/graemlins/cheers.gif
AUSMHLY
AUSMHLY
Thank you Velox and Shorn!
As always, I appriciate your taking the time to reply.
Velox, very nice photos.
Cheers, Roger
wangdango BJ8 foot well vinyl panels? Austin Healey 7
J BJ8 passenger foot well [LHD], right wall Austin Healey 1
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
