Wanted BJ8 FlyWheel
Robbie S
Hi My Friends, I am looking for a flywheel and ring gear that will fit the 6 CYL BJ8 engine, I can find a ring gear however no flywheels seem to be available new or used. Any help finding one would be appreciated.
Warmest Regards,
Robbie
Healey Nut
I may have what your looking for Robbie .
I have two Tri Carb engines that I made one good one out of . So I have a spare flywheel and ring gear do you need 8 or 12 bolt mount ?
Let me know if you still need one .
hughesparry2011
Luke Skywalker in Canada. I am looking for a good used late model BJ8 flywheel Part No 22B136 . 4 Bolt flywheel with 3 dowel pins (early BJ8's had two pins). Am also in Canada. Chris
Healey Nut
I have a four bolt 2 pin with ring gear and also have the clutch diaphram assembly to fit it if that is any use to you ?
dezand
If you are still looking for the flywheel, I recently purchased one from the Toy Shop in San Diego and he had it blanchard ground for me.
Paid $275
also David Nock at BCS said he has them, it was going to be $175 plus shipping and then I would have to have it machined.
I went with the Toy Shop because he was going north towards my area to go vintage racing and we met close to my house. Saved me the shipping cost and believe me the blanchard grind job was perfect.
Nick
hughesparry2011
Luke Skywalker in Canada Further to my post looking for a used BJ8 flywheel, I found a rare used one for Cdn 300 (about US $220) at piecesanglaises, a parts company in Laval Quebec. Chris
J BJ8 flywheel take some pounds off Austin Healey 17
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
