Greetings,
I am installing a new interior in my 64 BJ8. In the middle section of the dash there is a plate which holds 4 switches (lights, overdrive etc.) they are installed from the bach and held on to the dash by a chrome ring that is threaded on from the front. This ring has 2 notches in it allowing it to be turned and tightened.
Q. Is there a tool available that fits over the switches allowing the ring to be tightened down to the dash? If so where can I find it?. This is the second time I've had to recover the dash due to a slip of the screwdriver I was using and this piece is a bugger to R&R
Thanks
Thanks
