BJ7 HS6 Carb Baseline Setting
PeterB
I had new throttle bushing put in my carbs and I just finished rebuilding them. I am ready to put them back in the car to tune. Can anyone recommend the baseline settings to start with? I know the Jet is supposed to be down 2 full turns or 12 flats from flush of the bridge. What about throttle adj screw and fast idle adj screw? I heard throttle adj screw is 1 1/2 turns. Is that from what, screw just touching stop or after it is flush with bottom where it is screwed into.Thanks in advance.
vette
Your 12 flats should be a good start for the jet. Nobody gets to excited about the throttle adj screw because as soon as you start the engine you'll know if it was a good starting point. I think 1 1/2 turns on the throttle adj screw might give you a pretty fast idle. The turn count would start at the point that the screw just touches the stop. I have been using HD8 carbs for awhile so my counts might be off.
P
PeterB
Ok, so installed the newly rebuilt carbs in the car. 2 full turns on the jets and the throttle screw and fast idle just touching the cams but not engaging. Car fired right up fast but went up to about 2200 rpms and there it wants to stay. The car has never started so good or fast. Raised the jet 1 flat each and it didn’t seem to change much. The choke is not engaged either. Any ideas where to start to lower the rpms? Thank you
NutmegCT
Peter - maybe I'm missing something, but have you checked that the throttle connections are free, and not binding on something?
I remember on my TR3 the gas pedal connection that ran under the dash was frequently getting stuck on the firewall - result: high idle!
Tom M.
vette
If you have that fast of an idle with the adjuster screws not turned at all past first contact then something is hung up or the jets are still dirty, or bent, or just plain stuck. First thing I would do is to loosen the interlock clamps on the throttle shafts to make the carbs independant then make sure the throttle plates are all the way closed when at idle position. then make sure the shafts aren't sticking. Then make sure the throttle plates aren't sticking. Close the jets all the way up to full lean then make sure they can be pulled down with no sticking and that when released they return to full lean. then turn the jets down a few flats at a time and pull them down and release at each position to make sure they aren't sticking. I'm going to guess that your throttle shafts and blades aren't right. Also check the piston that it is not sticking and also that the needle is centered and not bent.
British_Recovery
Bronze
Check for a vacuum leak. Some fitting might also be missing. The drain tubes on the bottom of the intake manifold sometimes go missing.
vette
:iagree:
Absolutely, good point.
P
PeterB
It ended up being the interlock clamps on the throttle shaft. Once I adjusted them things dropped to normal. Thanks all.
BLong63AH HS6 BJ7 Carb Insulators Austin Healey 5
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
chicken HS6 Carbs for BJ7 Austin Healey 3
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
