Big Healey Air Filters
Gearhead_Garage
I have noticed that Big Healeys make a raspy air intake noise which I suspect is due to the sucking air through the "steel wool" stock air filters. I cleaned and refurbished mine but they don't seem very efficient to me and I really don't like the raspy noise. By way of comparison, Denis Welch has a modern foam filter that they say adds 8hp!
I would like to keep a stockish look so I have considered cutting them open and inserting air filter foam inside. It might be possible to remove the rear mesh and the "steel wool" through the carb hole. Has anyone done anything like that? Advice?
Patrick67BJ8
You didn't say what year of Healey you have.
The BJ8's HD8 carbs always "hiss" and It's normal even without the filters installed. The Denis Welch foam airfilter claims a 6hp increase for BJ8's and I installed one and I'm satisfied with it. If you get one be sure to get the foam chemical to recoat the filter after cleaning but you will have to buy that in the US because they can't ship it from the UK. KN makes a filter that can be used but you'll have to modify the rear filter(see www.healey6.com for this operation).
Gearhead_Garage
Gearhead_Garage
Thanks for the info on the hissing sound. I guess that is part of the experience, along with the exhaust note and the smell of leather mingled with unburnt hydrocarbons.
My car is a '64 BJ8 with HD8s. I really like the look of the pancake filters. While I am sure they would increase performance, K&N and the foam filters are too modern-looking for me. I like to buy things for my Healey but I like making things more so I might try to modify the stock filters.
HealeyRick
Obviously your exhaust isn't loud enough :devilgrin:
Gearhead_Garage
Gearhead_Garage
Actually it isn't. I am planning to cut off the rear BJ8 silencer and route the dual pipes out the left side like a BJ7. That should put some bark back in the old dog.
Patrick67BJ8
Before you modify your original air cleaners you might want to price out what replacements will cost you.
Jeepster
Before I fitted the correct exhaust system to my BJ8, the PO had installed a straight through system like on the BJ7 that exited the rear at the left.
It did produce a more raspy sound but it was too uncomfortable for longer journeys. The correct system is far more refined at speed over long distances and still gives a good note when revved.
andrea
I have new foam filters -I am not so sophisticated to measure the increase of power but my impression is that car run better
Consider also that MG A Twin Cam problems was debited at later date, to pancake filter resonance (n°4 piston subject to perforation)
https://picasaweb.google.com/lh/photo/jvhZqto5HYGALNMUyCvJJtMTjNZETYmyPJy0liipFm0?feat=directlink
this filter have a lot more surface and better air filtration for a 3000 cc engine for 1.25”, 1.5” and 1.75” SU
https://www.thepipercrossshop.co.uk/pipercross-px150-mini--metro-su-air-filter_p23378647.htm
or https://ramair-filters.co.uk/motorsport but I haven't find a SU filter
or a very economic solution for rebuild you pancake filters https://www.ebay.co.uk/itm/Car-Truc...trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=244
Keoke
Not a recommended place to experiment. Failure to get adequate airflow can choke the engine at higher revs.
Gearhead_Garage
Gearhead_Garage
Not a recommended place to experiment. Failure to get adequate airflow can coke the engine at higher revs.
Just about anything would flow better than the stock air filter. If I apply some common sense I think I can handle it. And I have an air/fuel meter and data logger to measure the result at various speeds and engine loads.
Gearhead_Garage
Gearhead_Garage
I did verify they are available and not cheap. On the other hand, if I destroy mine I can buy the shiny stainless ones!
Gearhead_Garage
Gearhead_Garage
I have solicited several opinions on changing the BJ8 exhaust and of course sound is a matter of personal taste and hearing (both mine and the spouse). One Saturday, I am planning to disconnect the rear silencer and drive around a bit before I do anything rash. I sure would like to lose 10 lbs and gain some ground clearance in the rear (that's what she said!). The sound is really mellow right now and that is not a bad thing.
Patrick67BJ8
Hendrix Wire Wheel has been fitting taller tires to the BJ8's giving more ground clearance. I have a set with new wheels and no issues so far with my new exhaust system. I also had new rear springs made to make the BJ8 sit "level"(I hate the "jacked up" look).
steveg
Am kind of surprised if the stock filters don't flow well. Road & Track used to call them "gravel strainers". I mean, can't you see daylight through the mesh? IMHO flowing's not the problem, it's the admission of dirt and objects.
FWIW - I'm using K&Ns.
Just my 2 pence.
bluegrass john
Your car has the look I am hoping to get with my BJ8.................not jacked up but level!! I wish I knew where to buy a set of springs that would give me the look you have achieved. I have seen too many BJ8's that have had new springs installed but they are too high. I know these cars were higher when new but they did not have the jacked up look that I see now. I would think that 28 inches would be the maximum measurement from the ground to the top part of the wheel opening. I have measured some cars that are 29 inches or more.
John
Patrick67BJ8
John
My springs came from Jule Enterprisesin Canada. "NFI" (They also did my new frame). They cost about $300.00 plus shipping. The wheels/tires are from Hendrix Wire Wheel "NFI". You'll need about 26 1/2" to 27" clearance between the bottom of the dogleg to the front of the rear fenders for the taller tires to clear the fender opening. The taller tires fill up the wheel opening quite well.
And, I have finally have a Healey with absolutely NO scuttle shake!
Jeepster
John
When restoring the rear suspension on my BJ8, I ordered a set of replacement springs from one of the usual parts suppliers and was shocked to see how much they differed from the originals (car sat just right on the originals but some of the clamps were shot). If I had fitted these, the car would have been so high at the rear.
I sent the springs back and decided to have the originals refurbished. They guy that did the refurb added a little extra bend to allow for them settling in and the fact that they had probably dropped somewhat over the years. I was very pleased with the result and the car sits about right. still havent done enough miles as yet for the car to bed in fully.
bluegrass john
You gotta admit though, is was a smooth & seamless transition but it still was about "noise".
I am glad that "easy morph" was made; gave me a chance to find out where the springs came from.
Patrick, do you think the Jule springs would work as well concerning ride height and quality of the ride with an orginal frame that I know is more flexible than the Jule frame...........I suppose I am wondering if the Jule springs would be too stiff for the more flexible orginal frame. Any thought are appreciated !!
John
bighealeysource AIR CONDITIONING IN A BIG HEALEY Austin Healey 12
R Big Healey 100 Head Austin Healey 4
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
R Wanted WTB Big Healey Austin Healey Classifieds 3
dougie Big Healey Six - Used the Right Way Austin Healey 5
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
dougie 1963 Sebring Big Healey 57 FAC Austin Healey 4
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
dougie Big Healey 6 Racer For Sale Austin Healey 2
AngliaGT Big Healey Spotted 0
coldplugs Big Healey near Portland OR Spotted 3
HealeyRick Bugeye Colored Big Healey Austin Healey 0
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
dougie Silodrome - Big Healey Buyer's Guide Austin Healey 4
Marvin Gruber Big healey coil springs Austin Healey 7
HealeyRick Last Big Healey? Austin Healey 20
Marvin Gruber Big Healey ridged hood Austin Healey 13
AngliaGT Red Big Healey Spotted 0
maxwedge5281 bumperless big healey photos!! Austin Healey 34
Marvin Gruber Big Healey clutch question Austin Healey 3
apbos So Cal Big Healey- can someone examine for me Austin Healey 3
John Turney Another Chance to Own a Factory Rally Big Healey Austin Healey 0
Tronch Big Healey heigth increase Austin Healey 1
maxwedge5281 wtb ubolt plate for big healey Austin Healey 7
HealeyRick Big Healey Tuning Information Memos Austin Healey 0
A Project Small Axe Racing: Big Healey restoration/vintage racer build Racing 30
JPSmit When I grow up I wanna be a Big Healey Spridgets 5
maxwedge5281 differential interchange for big healey Austin Healey 6
dougie Nurburgring in a vintage racing big Healey Austin Healey 3
aeronca65t Big Healey-strange wheels Austin Healey 12
toysrrus "Pickens, SC" resident Searching for "Bernard" in "Liberty, SC" with a Big Healey Austin Healey 0
maxwedge5281 rear springs on big healey Austin Healey 4
Keoke SS Bumpers for Big Healey Austin Healey 1
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
A Big Healey Restoration Do's & Don'ts Austin Healey 11
DerekJ Big Healey Race - Castle Coombe Austin Healey 10
JPSmit OEW-big Healey Spotted 0
dougie 767 KNX Works Big Healey Up for Auction Austin Healey 4
HealeyRick The Cars the Star - Big Healey Austin Healey 6
Lin Big Healey Roadster Windscreen to body Rubber Seal Austin Healey 0
H Another big Healey coming my way? Austin Healey 3
dougie '56 Big Healey Racer - Racing 7
TulsaFred Help me analyze a potential Big Healey purchase Austin Healey 11
dougie WANTED.... More Big Healey Racers Austin Healey 8
tri_carb_healey big healey salute to fatherhood Austin Healey 9
HealeyPassion Big 6 Healey engine builder Austin Healey 26
60TR3A Big Healey Expert Needed in Florida Austin Healey 3
