BE hood strut finish
lbcfan
I've had my struts sandblasted without thinking about the new finish. Do these need to be powdercoated, or will paint work? I'm not sure that paint will hold up with the sliding action, and I don't want to gum up the mechanism.
Thanks.
Michael
smaceng
The struts were not painted from the factory. They had a bright steel like finish. They may have been cad or nickel plated, but at the rate they rust, they may have been uncoated.
Scott in CA
jlaird
I think they were cad plated, in any case not painted.
Sarastro
Paint certainly won't hold up, and I doubt that powder coating will, either. You probably don't want to leave them unfinished; they'll rust. Mine were galvanized. I'd get them galvanized or cad plated. Galvanizing probably will show wear least.
bug_sixty
Am I missing something.. are you talking later style windshield struts?..if so the Works finished them by anodizing as well as the windshield frame, the upper door and back cockpit trim.. That being said, restoring a beat-up surface for plating can be a challenge.. choose your plater with care.. (front CPT was covered with the same vinyl as the dash) Many a car owner has chromed instead which leaves a completly different look...It's all through the eyes of the Master
2091351
I believe Michael meant 'bonnet' not 'hood'
L
lbcfan
Re: BE hood [bonnet] strut finish
I indeed meant bonnet, not hood.
Thanks for the feedback. Plating seems the way to go. Unfortunately, the downside of making everything new is that I can't count on a film of oil and grease to preserve the parts anymore.
Michael
jlaird
They are cheep enough, why not buy new??
L
lbcfan
It hadn't even occurred to me to me to buy new. Thanks for the thought.
rkep01
Y'know, looking at the action of these struts and the way they operate, it's a very simple but ingenious design. I don't have my Horler's at hand, but I think the originals were nickel plated. Obviously the plating doesn't stand up very well either - witness all the struts with the plating worn off. I would say if you don't want to buy new, clean them up well and paint them with https://www.vhtpaint.com/products/platefinish/
L
lbcfan
Thanks for the source. I was also thinking about a coat of clear lacquer to keep the finish thin and to hide any wear- the metal cleaned up pretty well.
rkep01
Give us some pictures when you're done. I'd like to see how it turns out.
jlaird
I use hi temp clear coat for protection under the hood. Seems to work well. Comes in a spray can.
Whitephrog
I did the same as Jack. For the struts, I let the soak in EvapoRust for about 24 hours. Cleaned up nicely.
L
lbcfan
I need to figure out how to upload photos. Considering that I've refinished the engine compartment with spray cans and gel filler it looks ok. Never intended to go this far though...
jlaird
Button at bottom of quick reply. says full screen, click. Then at bottom of entry square find file manager, click. click, choose file to select one from your computer, click, open file. click add file, click done. click submit.
JPSmit
and note that you may have to resize your photo size depending on your level of membership. None paying restricted to 100kb, Silver - 150kb etc.
L
lbcfan
Thanks all for the info re photo uploads.
I wanted to mention that I finally used a flat clear "paint" on the struts and it works fine. Plenty of room in the channels to avoid gumming up the works with the paint.
Michael
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
J TR2/3/3A Hood oilcanning Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
D TR2/3/3A Under hood Photos Triumph 7
4tecdog Modify frog hood frame Spridgets 12
