MGB B engine sputters,stalls and restart in seconds
bgtrn
Member
Hello, My 70 BGT has developed a strange problem. While driving, it will start to spuutter, stall and restart itself, within 3 or so seconds. It runs great before and after. All this happens while still in gear, it is so sudden. Has occured 3 times this year. Fresh Curto carbs and Advanced dizzy rebuild. Don't want to start the replace this, try that scenario; any thoughts???????
JPSmit
I would check fuel supply - either floats or crud in the pipe - do you have a fuel filter? and when was the tank last cleaned?
My first guess though would be floats based on the fresh carbs.
B
bgtrn
Member
Hi, yes have filter before pump and one before the carbs. Tank is 12 years old, never thoght to clean it. Will check bowls for crud fron tanh. easy place to start. thanls....
PAUL161
Our 72 B did that, would run for a bit then shut down, would restart in a short time. Found out it was the flex line between the tank and pump had a fine crack in it allowing air to enter. Setting still, the pump would fill the carb bowls, but would not supply enough fuel to keep it running at speed, replaced line, never had a problem again. PJ
bob67bgt
Agree on a fuel issue. If it was ignition then it would probably have a loud backfire thru the exhaust when it came back to life. Good luck with the repair!
Brinkerhoff
I can tell you that when the SU fuel pumps fail , they often give signals like this when is sunny out , so that you can have a new pump on order for when it quits while its raining out. But it could be other things.
59diamond
My Bugeye would act like that sometimes, until I figured out I was hitting the key while shifting and accidentaly turning off the engine. no more incidents like that
Sopwith_Camel
I've been having the same issue with my 70GT. i was putting in a new fuel pump (throwing money at the problem) i broke the pipe to the tank and at its high point it had a hole, but I still get spluttering over 30000 rpm, so i can get home from a test drive but i can't give it some Welly.
new tank and fuel pump, dissy, coil, wires, plugs, carb rebuild. and compression tested 3 times.
steve
E Engine Sputters MG 8
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
