Austin Healey 3000 BT7 1960 VIN chassis STAMP location
Smooth
Hi,
I'm looking for the VIN number stamped in the chassis of my Austin Healey Mark 1 BT7 from 1960.
I've looked on the right front shock mount where it's placed for later cars (BJ7/BJ8) but apparently this BT7 doesn't have that. So it should be somewhere else?
Anyone have any idea? Perhaps it's a plate attached to the chassis? (I'm not talking about the plate above the motor under the window..)
Thanks in advance!
With kind regards,
Joe
S
Smooth
Hahaha, thanks! ;)
I know where to look when it's a BJ7/BJ8 (it's on the horizontal upper piece of the shock mount, on the outside, you have to turn the wheel and scrub till it appears).. So I figured it must be somewhere else? Or did they just introduce that after 1960? Seems odd..
Anyone else have any experience with this? Thanks!!!
Brinkerhoff
There is a number stamped in the shock tower area but doesn't seem to be related to the VIN , from 3 early 3000s I've seen. There are no other number stampings on the chassis like Derek said.
BJ8Healeys
The number stamped on TOP of the right-side shock tower (forward of the shock absorber, at least on BJ8s) was apparently put there by the manufacturer of the frame (either John Thompson Motor Pressings, or Jensen Motors, I'm not sure which). I would assume it was a number that was useful to keep track of the production of the frames, but no cross reference to the chassis number of the car exists, to my knowledge. In many cases, the number has been partially obscured by weld beads and no longer legible in toto by the time the frame has been completed. I guess its usefulness was finished past a certain point in manufacturing.
However, there is a subject for everyone in the Healey world to be interested in, and there is someone who has a particular interest in these numbers and collects them. He says that the numbers apparently started over when a significant change was made to the frame. Anyone who wishes to contribute these numbers to the effort to understand them can submit theirs to Rick Regan. I know of his interest, but I don't know if he wants his e-mail addressed published to the world, so contact me and I'll help you make the connection with him.
It is my understanding that the VIN stamped into the shock tower is only there for BJ8s (and not BJ7s, but then I do not collect data for BJ7s). Some BJ8s have also been found with the complete VIN or only the chassis number stamped into the passenger's side (LHD cars) floor, just in front of the seat.
S
Smooth
Hi Steve,
The number you are referring to is on the 'inside' of the shock mount, this has nothing to do with the real VIN or 'chassis number'.. I've read somewhere this number was for company puroposes, in case you lost the badge, they could look it up back in the days.. Not sure if this is true..
But there is another number on the 'outside' of the shock mount (the above horizontal piece), turn the wheel and if you scrape off the paint you'll find the VIN number..
But it seems this is only for BJ7's or BJ8's.. (BJ7's deffinitely have it too) Normally all cars should have the VIN number stamped in the chassis.. Somewhere.. Just couldn't find it for the BT7 yet.. But if the messages above are true a BT7 from 1960 doesn't have a chassis number stamped (I'm not talking about the badge on the fire wall)..
Perhaps other BT7 owners have more insight into this matter, or can confirm the total lack of a chassis number stamp.
healeyblue
You basically just said what Steve said. He definitely knows about the VIN stampings on the BJ8's. You can stop looking for the VIN stamp on your BT7. It's not there, never was. I have pictures of various other stampings on our BN4 in those areas (shock towers) and other areas and I believe they may be some kind of QC stampings during assembly.
vlust
Hi Joe,
I own a Healey 3000 Mk.1 BT7 from 1959. I have the same discussion with the Dutch Road Traffic Authorities ('Rijksdienst voor het wegverkeer') Probably the Belgian authorities tell you they can not determine the originality of the car because the Vin number is on a plate screwed to the firewall. I have done extensive research on the matter and agree with the other members that there is definitely no numbers or whatsoever stamped on the body of the Mk.1 Healey. Back in the days they just did not do that. According to Gary Anderson & Roger Moment, Authors of the standard book “Austin-Healey 100/100-6/3000 Restoration Guide”, page.67 :“the chassisnumber was stamped on a plate screwed to the firewall, and is theone generally used as the vehicle identification number(VIN) for governmentregistration…….The car’s chassis number was not found anywhere else on thebody on the six-cylinder roadsters.” If you want to know more please send me a pm.
fogol11281
Buona sera io ho una bj7 e ho stampato nel telaio davanti a destra vicino all'ammortizzatore un numero di 4 cifre ( 4584 ) che non corrisponde a nulla dell'heritage in mio possesso. ho lo stesso problema perche' devo immaricolare l'auto in europa proveniente dagli USA e spero di arrivare in fondo.
Qualcuno puo' dirmi dove posso cercarlo?
saluti
alberto - italia
NutmegCT
Alberto - come vedi nel posto no. 6, di Smooth -
"Ma c'è un altro numero "all'esterno" del supporto dell'ammortizzatore (il pezzo orizzontale sopra). Gira la ruota e se gratti via la vernice troverai il numero VIN .. Ma sembra che questo sia solo per BJ7 o BJ8.."
Alberto - as you see in post # 6 from Smooth -
"But there is another number on the 'outside' of the shock mount (the above horizontal piece), turn the wheel and if you scrape off the paint you'll find the VIN number.. But it seems this is only for BJ7's or BJ8's.."
Tom M.
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
C Austin Healey 3000 in Modsports Austin Healey 4
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 2
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
BN6 Austin Healey 3000 Cylinder Heads Austin Healey 19
pbraun For Sale 1963 Austin-Healey 3000 BJ7 Austin Healey Classifieds 5
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 2
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
R Repair a First Motion Shaft for a Austin Healey 3000 Austin Healey 7
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
S A $50 Austin-Healey 3000???? Austin Healey 4
apbos Austin Healey 3000 Hardtop SFO NFI Austin Healey 18
A Austin Healey 3000- head configuration Austin Healey 10
V Austin Healey 3000 Vehicle identification plate Austin Healey 7
A Looking into to buy a Austin Healey 3000 Austin Healey 5
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
F Watch Bruno Sena Drive Austin Healey 3000 - The Classic Car Show on UK TV recently Austin Healey 1
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
G Common Years for Austin-Healey 3000 frames Austin Healey 5
Chuck9482912 Rust holes in engine of Austin Healey 3000 Mk II BJ7 Austin Healey 22
BOBBYR Austin Healey 3000 Restoration by Gary Anderson Austin Healey 21
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
L 1960 Austin-Healey 3000 on "Chasing Classic Cars" Tonight Austin Healey 3
N I am eyeing up an austin healey 3000 2+2 Austin Healey 19
Hot Wings 1961 Austin Healey 3000 BT-7 4 sale Austin Healey 10
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
AH67 Steel Louvered Bonnet/hood for Austin Healey 3000 Austin Healey 1
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
H Accessing clutch plate on Austin Healey 3000 BJ7 Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
F Is the Austin Healey 3000 a midengine design? Austin Healey 12
F Austin Healey 3000 Mk II Sales Brochure Austin Healey 19
K 1966 Austin healey 3000 Austin Healey 10
Johnny Austin Healey 3000 BJ7 gearbox rebuild Austin Healey 16
F 67 austin healey 3000 clutch problem FORUM Navigation Questions 0
