Anyone fitted a flywheel ring gear?
burgundyben
I got a 3 syncro 5 bearing flywheel to fit in my 1800 5 speed conversion.
It needs a new ring gear, I got one today.
I got the old one off easy by drilling some holes and then cutting through the remaining metal with a chisel and off it popped.
I put the new one in our oven with it on its highest setting, waited for the light to go out, showing its reached max temp, gave it ten more mins and took it out to the garage to try and fit it, its about zero centigrade outside tonight so flywheel should be pretty well shrunk. It was kind of close but I could not get it on. I tried a couple of times but no luck.
Anyone done this? How hot do they need to be?
Ta.
Ben
jlaird
Easy way is to take to machine shop and give em 10 bucks.
Otherwise move faster from oven to garage and have your hammer ready.
PAUL161
We used to put 6 foot ring gears on truck crane turntables by heating the ring gear to 800 degrees and packing the flange in dry ice. You have to be quick. 20, 30 degrees is not cold enough to shrink anything the amount you need. If it was, it wouldn't be tight enough. Without the right equipment to do the job properly, I'd do what Jack suggests and send it out. If it was mine, I'd have the balance checked also after the gear was installed. A high frequency vibration you don't need.
Platinum
Done it once with the oven to 450*F, the flywheel on below zero concrete. Moved fast enuff but it took a bit of whacking. ISTR three shots. Mom was NOT impressed. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Now the machine shop gets the job.
V6MGB
Did this many , many years ago and never again.
The dry ice and oven method works but it really was a lot of mucking around for a result which would have cost a small amount of money to pay to have done.
One point: Make sure the ring gear is the right way round. Some only go on one way and are usually indicated by an arrow or mark of some sort.
Good luck , Pete.
Bruce74B
Make sure to clean both surfaces of all particles that will make it more difficult to mate the two pieces. Give the flywheel once more wipe while heating the ring and the two should go togther smoothy if you are prepared and move quickly...good luck!
tony barnhill
Great Pumpkin - R.I.P
Not worth the hassle to save a few bucks - take it to a machine shop...they're doing one for me right now.
piman
Hello all,
I've done two or three, no heating or cooling. It does take a bit of patience and alignment given the large diameter and small depth.
You will be struggling with a hot bit of metal to get it aligned correctly to drive it on, else it has to be so hot to slip on.
Alec
JeffS
I helped with mine at the machine shop last year. Old one came off with torch work and sledge. New one went on relatively easy with torch heat (slow, even, gradual torch work) and a frozen center. It didn't exactly fall into place, but only took a few minutes.
M TR4/4A Anyone here fitted a Honeybourne Surrey Top to their TR4 Triumph 1
catfood Collapsible Steering Column on a BN1/BN" - Anyone fitted one? Austin Healey 4
Basil Anyone remember Dave Russell? Austin Healey 9
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
