Advanced Distributor
BOBBYR
Hello Gentlemen,
I hope everyone is doing well . Last night I was reading a post on timing advance and noticed a couple entries mentioned Advanced Dizzy . I looked around the net and found a company called Advanced Distributor . Anyway , I was wondering if you guys have used this company for your distributor rebuilds and what you think of the results . As always , I appreciate your help . Thanks Guys,
BobbyR
dklawson
Yes, I have used him. He rebuilt a distributor for me about 10 months ago.
Jeff can rebuild a distributor to the factory standard spec or change the curve a bit to what he understands will work better for your particular engine. It is worth your time to have a brief discussion with him on the phone and then make your decision on what type of rebuild/recurve you want. He is easy to work with and he does quality work.
Jack T
Hello Gentlemen,
BobbyR
Jeff at Advanced rebuilt the distributors for both my Jag and Healey. I would highly recommend him.
BJ8Healeys
I used them a few years ago to rebuild the Lucas distributor for my '73 MG Midget. The rebuild appeared to be quality work, and I've had no problems with it since then.
Gliderman8
You can't go wrong with Jeff at Advanced. He rebuilt two of mine.... it was like night and day after getting the dizzy back from Advanced.
Patrick67BJ8
I've had 3 distributors overhauled by Jeff, very satisfied customer. He will call you with any questions.
He did two fir me and they work great. You can also send your cap n wires and he’ll check them out too. He sells the good rotors, the red ones.
BOBBYR
BOBBYR
Hi Gang, I appreciate all the input . I'll give Jeff a call tomorrow and put this repair in motion
Thanks Again ,
BobbyR
T "Advanced Distributor Inc"+Reviews? MG 25
MGTF1250Dave Lucas Distributor Rebuilt by Advanced Distributors Triumph 15
Brosky Distributor Overhaul 101 by Jeff at Advanced Triumph 16
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
G TR2/3/3A Advanced Timing Light for TR3? Triumph 6
J Plug for Advanced Distributors Spridgets 4
Simon TR4a Technically advanced Triumphs. Triumph 37
T Advanced Distributo new red rotor Triumph 19
Moseso Advanced Ditributors report Triumph 10
PAUL161 Thanks to Jeff Schlemmer of Advanced Distributors! MG 12
Michael Oritt Advanced Distributors Austin Healey 3
Michael Oritt Advanced Distributors Racing 1
T Plug for Jeff at Advanced Distributors Triumph 5
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
