Lucas Distributor Rebuilt by Advanced Distributors
MGTF1250Dave
Aloha All,
Let me be the next to endorse Advanced Distributors. The forty-nine year old distributor was badly worn and needed to be repaired or replaced. I discovered this while trying to set the points. I found I could push laterally on the rotor shaft and open and close the points. I followed several discussions on the BCF about replacement options and decided to send Jeff an e-mail to see if he thought he could repair it. I was pleased when he was confident it could be brought back to a better than new condition. So off went my distributor in the mail. In less than two weeks it was back, looking good as new. It had been recurved for a smoother advance and the vacuum advance unit was tested. The first noticeable impression was that the car idled smoothly at about 600 RPM. I had power and good acceleration from low RPMs which I didn't have before. The fuel efficiency has improved by 16%. So, for about half the cost of a new replacement distributor, I have the original (albeit only the housing) in a new and improved condition.
Brosky
Nice to see that I'm not the only fan of Jeff's.
T
Tinster
Hey Jeff,
Don't forget it was your dizzy with electronic ignition
that was the final piece in getting the Crypt Car's engine
running.
Thanks,
tdskip
Even my fat fingering the installation (evidentally) can't keep Jeff's good work from shining through.
Now if only Jeff rebuilt ZS carbs....
T
Tinster
Re: Lucas Distributor Rebuilt by Advanced Distribu
Crypty can also attest to Jeff Palya's
most excellent carb restoration work.
Pretty much bolt on and turn ignition key.
d
YankeeTR
Many of us, me included, have been duped by ads that have convinced us that "updating" to the 'new and improved' gizmo will make our favorite car run so much better. Many times we find out that a simple rebuild of the original parts is a much better solution.
TR4
How long does it take to have a distributor turned around by Advanced Distributors. It's so close to driving season, I may have to wait until next winter.
T
Tinster
About a week/ten days for a dizzy with Jeff.
Yankee, I pretty much agree with you.
I mostly try to refurbish Crypty's parts whenever
possible. I too have been disappointed with the
quality of some of the new parts I had to purchase.
I cannot say enough good things about Jeff and Jeff!!
And let's not forget Ace Mechanic Dave from Canada!!
"Have torque wrench-will travel".
d
tomshobby
I sent mine to Jeff about 2 weeks ago and it was back in a week from the day it was shipped. He did a great job, the dizzy looks great, and the car ran much better (only did a trial run before starting an engine build). He fixed things that I did not realize were wrong, installed the Pertronix system, tuned the dizzy for the planned engine mods, added an adjusting thumb wheel to the advance, and put together an additional plate with a points set in case of emergency.
His price was most fair and I feel it was a very good value.
And Jeff was great to work with during the project.
Flinkly
he is quick, and they look great. i haven't tried mine yet, but i have no doubt that it will work flawlessly.
MGTF1250Dave
MGTF1250Dave
I sent mine to him via the US Postal Service and that was how it was returned to me. It entered the system in Hawaii on 8 Feb and I had it back 19 Feb. Jeff is quick he received it 14 Feb and send it back on the 16th. So the longest period of time was transit time, i.e. "in the mail". Jeff is also very good about telling what he thinks needs to be done and how much it will cost.
Brosky
Do yourself a favor and do it now. Then you will enjoy this season so much more. Contact Jeff and ask what his lead time will be before you pull it out.
R
RonMacPherson
Dave, you didn't make it to the club meeting tonight. We missed you.
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
D TR4/4A Lucas 23D4 vs 25D4 Distributor Triumph 4
lbc_newbie Lucas electronic distributor - do I need a coil? Spridgets 1
angelfj1 TR2/3/3A TR3A Lucas Distributor Triumph 6
19_again GT6 Lucas Distributor cap on Delco D204 Dizzy GT6+ Triumph 6
S Rotax - Lucas Distributor? Other British Cars 4
tosoutherncars Distributor question - Lucas 41216? Spridgets 1
T Is the Lucas distributor cap really 3 times better Triumph 9
I Vacuum advance unit for BN1 [Lucas DM2 distributor Austin Healey 2
F Lucas distributor identification... Triumph 12
Tinkerman Lucas Distributor Cap Color Triumph 2
R "Lucas" Distributor Cap Needed Austin Healey 16
S Wedge TR7 Lucas Distributor Part Number Triumph 3
H Lucas Vs. Delco Distributor thanks Triumph 0
H Lucas VS Delco Distributor question Triumph 9
racing girl Lucas Distributor British Motor Corp 3
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
