A beat up box arrived
T
Tinster
Well, just looky here what was sitting on my front
porch this AM. A beat up, water drenched, sodden,
partially opened and retaped shut Priority Mail box.
Thankfully the contents were packed in a plastic, ziplock
baggie.
An awesome gift from fellow BCF member Browsky. A 100%
restored, rebuilt, refurbished, Jeff Palya micro-polished,
mechanical fuel pump for my recently operational 1969 TR6.
Now I can swap out my jerry rigged "made in India pump" for
the Real McCoy.
Thanks so much Paul, WOW!!! What a great gift.
best regards,
dale
TR4
Very nice, ask and you shall receive. What's next on your list Dale?
Brooklands
It reminds me of the package we sent to our daughter one year containing Easter Candy. Because the local Postal sub station used the wrong color ink to cancel the stamps, it was dunked in water to prevent explosion, then returned to us.
Brosky
What is it with the PA Post Offices???
I mailed my daughter in western PA some cards two weeks ago and she still hasn't received them. She mailed me a CD in November and it took three weeks to get here. It's the same if TRF mails to me. UPS is fine, but the mail finds a slow horse to send it on.
Dale, now you know why I packed it like I did.
NutmegCT
Brooklands: "... it was dunked in water to prevent explosion, then returned to us."
now Dave knows never to send Pop Tarts through the USPS.
T.
T
Tinster
Paul-
Thanks again!!
A true story.
Back a few years, I flying from Philly to Chicago
on business. A nice clear day and we were over western
Pennsylvania when the Captain announced:
" Ladies and Gentlemen- we are now flying over Altoona, Pennsylvania:
- please set your watches back 200 years."
You'd have to know the area to get the chuckle.
I believe Priority Mail in western PA means a two mule
team buckboard------ instead of a lone guy riding a nag.
d
G
Paul, is that the old OE fuel pump off my car that I gave you! If it is, I feel good that my car may have been a "organ donor" for Dale's baby. Life is good.
philman
Looks like the package went through the Small Parcel Bundle Smasher.
Brosky
Bill,
It is not your old pump. Dale got one of the pumps that I bought on eBay.
This is your old pump, which will be going on my new engine.
And no, you cannot have it back......
Brosky
I had a lot of time on my hands this winter. Since I gave up cold weather golf, the Triumph has improved greatly.
T
Tinster
Just wondering?
Are the inflow and outflow fuel pipes the same diameter?
If yes, what diameter pipe?
Also, the 2 brass fittings for the pump- with the holes in
the middle for the fuel pipes-are they tapered or straight?
I have one old brass fitting and it seems to be straight.
I can spin it into both the pump holes with no binding.
The brass fittings at Ace Hardware and Home Despot all seem
to be tapered and bind tightly after maybe not even one
revolution.
thanks,
dale
MGTF1250Dave
Aloha Dale,
The threads on the input/output fittings should be straight. That is why the compression sleeve is needed to make the seal between the fuel line and the pump. Tightening the fitting crushes the compression sleeve against the fuel line and the taper in the fuel pump.
Measure the ID of the hole in your brass fitting, I suspect it is slightly larger the 5/16".
TR3driver
Great Pumpkin - R.I.P
Don't know if this applies to the TR6 pump, but it does to the TR3. The factory compression sleeves were a different design than modern ones, tapered on only one side instead of both sides. The result is that modern compression sleeves frequently will not seal, because the nut bottoms in the threads before compressing the sleeve far enough.
I solved my problem by machining a custom nut on the lathe, but Scott Suhring's solution looks more practical.
Banjo
Tinster said:
Paul-
Thanks again!!
A true story.
d
I once had to take a truck and trailer down to Altoona to pick up a TR3. We had sold it through a shop I was working at, and the customer was having problems. Turned out the inside of the fuel tank was nasty and clogging the pipe.
But I found some nice little twisty roads just outside of Altoona to go for a test drive while trying to diagnost the issue.
Definatly a step back in time in that region.
P Honda Beat Other Cars 4
S Beat Up Old Suburban Other Cars 13
Geo Hahn General TR British Euro Auto Tour [BEAT] Triumph 2
B TR2/3/3A Beat my transmission tunnel to death? Triumph 12
richberman anyone have beat up steering column? Austin Healey 2
Geo Hahn Arizona BEAT Triumph 4
Brosky Beat the snow - home safe in the garage Triumph 11
ronzet And the beat goes on... NEW PHOTOS MG 16
A TR4/4A TR4A missing a beat Triumph 15
bugimike sometimes you beat the mountain and... Racing 11
Basil GO beat the bushes! TVR 11
V TR6 DYNO Test of my TR6; Can you beat it? Triumph 9
J MG sold ! If this doesn't beat all! UGH! Guess who MG 9
Basil MGB MGB beat my beloved EType! MG 13
T Beat me... Kick me... MG 7
X how to beat the smog test Restoration & Tools 4
L T-Series Gear box servicing cap. MG 5
Todd78d Sprit MK1 gear box filler Spridgets 2
T 1971 Fuse Box and Wiring Triumph 7
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
N TR5/TR250 Starter Box Assembly Leak Triumph 14
W General Tech 2500S starter motor and fuse box questions Triumph 3
Popeye General TR Old robbins top in box Triumph 7
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
R TR6 Heater box Triumph 6
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
B MGB 1977 MGB Battery Box and Shifter knob MG 4
Martinld123 Steering Box Leak Austin Healey 27
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
F TR4/4A Locked out of glove box Triumph 1
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
A MGB MGB a glove box door MG 10
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
AngliaGT MGB-GT How Do I get the Glove Box Opened? MG 16
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
D Socket for TR3 Gear box drain plug Restoration & Tools 6
M TR6 Fuse box wiring mystery Triumph 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
D TR2/3/3A Battery Box drain Triumph 9
Basil Now THIS is a tool box Restoration & Tools 6
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
