MGB 6ft3, MGB - only solution to chop my legs off?
JonnyEye
Hi everyone,
I posted on the Spridgets forum a little while ago, asking if I'd squeeze into a Midget - I'm 6ft3 with very long legs....and it was recommended that I try an MGB instead...
So imagine my disappointment today when I went to test drive a BEAUTIFUL 1969 MGB and found it almost impossible to drive....my right leg bent in at an odd angle and the (original, very big) steering wheel locking against my thigh..
The dealer suggested a smaller steering wheel would solve the problem but I'm not so sure that will do the trick on it's own.
Should I just give up on this whole idea? Or are there some more radical fixes? Can the seats be lowered any further? Can the steering column be shortened? Any other bright ideas?! Really want one!
Thanks!
Jonathan
/ubbthreads/images/graemlins/england.gif
There are several things you can do...14" Tourist Trophy wheel from Moss will take care of the wheel on leg problem - I've done it on most of my B's...Pontiac Fiero seats modified to fit in the original MG seat holes & tilted just a smidge helps as they'll slide a bit further back & are a little lower....they're easy to modify & M. Mike leather covers make them look right at home.
I'm 6'5" and 235#'s, 53 years old, have the standard wheel, and drive my 76 MGB with no problem. Yes, your right leg is going to be bent somewhat. You get use to that. My seats are old, and the foam is compacted somewhat, so that allows me to sit low. I drive with the seat all the way back. My left leg can actually stretch all the way out when not operating the clutch.
I've driven my car for 5 hours straight, and don't have any more trouble getting out of it than after driving my F150 pickup for the same time. And even if I did, I'd much rather be driving my MG than the pickup any day of the week.
Being a bit of a contortionist is a small price to pay for owning and driving an MGB!
Me too....Six foot three and over 250#, 50 years old. My 69B had a little larger wheel, but I was smaller back then (about 25 years ago)and my '74 has the stock, but slightly smaller wheel than the 69, and I fit comfortably in it. Some people laugh because my head is higher than the windshield, but the leg room is not much of a problem, once you get used to it. I drive a Chrysler LHS and a Silverado, so I am used to plenty of room in other cars. Never stops me from drivning the B every chance I get to! /ubbthreads/images/graemlins/driving.gif
Bruce /ubbthreads/images/graemlins/cheers.gif
Re: 6ft3, MGB - only solution to chop my legs off
6'3" and this was one of my concerns when buying mine. I first thought I'd need to buy a smaller wheel, but with the seat all the way back it's actually very comfortable. Someone on the forum had suggested cutting a bit of foam out from the seat, which sounded like it could do the trick too.
Besides cutting a bit of foam out of the seat, the seat slides that bolt to the floor have 3 sets of mounting holes in them. The seat can easily be moved further back on its floor mounts to allow more leg room. I have a friend who is 6'5" tall and he drives my B with no problems. I'm 5'10" and can move the seat to accomodate myself as well.
The foam modification is a relatively easy one. Simply notch the foam around the seat frame a bit. It'll make sense if you take one apart to look at it. If your seats have replacement foam, they are higher than stock! You can also replace the seat webbing that supports the foam with the older style (Pre-'71) diaphragm. That will allow the foam to sit lower as well.
[ QUOTE ]
[/ QUOTE ]
Sure, JonnyEye!!! Do like Dan (100DashSix)!!! /ubbthreads/images/graemlins/hammer.gif
Buy a Big Healey!!! /ubbthreads/images/graemlins/angel.gif /ubbthreads/images/graemlins/grin.gif
Try one on for "size"!! /ubbthreads/images/graemlins/jester.gif
Ed
To change the subject somewhat, do the Fiero Seats look good in a MGB, or maybe some Miata seats? I have thought about putting in something different in my 73'. They need redoing anyways, but I dont want it to look totally mismatched.
Thanks
Newkie
Fiero Seats:
What are the door armrests from tony? They almost look like they came from the factory that way.
Kenny - those door handles are also from a Pontiac Fiero....I dyed them to match the seats (actually, dyed all the panels as well)...just screwed a piece of metal to the door so there'd be something to fasten them to.
looks good /ubbthreads/images/graemlins/thumbsup.gif
I'm 6'5+" and have no problem driving my '80B. Remember, you don't get in an MG... you put it on.
J I'm 6ft3 - any point even trying a Midget?! Spridgets 20
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
