55 100 BN1 Carbs
Gray_Cat
The float chamber lids on my 55 BN1 carbs have cutouts on each side of the hole for the retaining bolt. Are these to be unsealed? Are they for overflow? If so, is there supposed to be an overflow pipe? I've not encountered anything like them before so not certain about their function.
Also; what is best for gaskets when bolting the float chamber to the carb body? The original type or the rubber grommets that seem to be in the rebuild kits? Candidly, I tried the rubber grommets and they didn't work too well - maybe my inexperience? Any and all help very much appreciated! /ubbthreads/images/graemlins/hammer.gif
Dave Russell
Yoda - R.I.P
On the type H carbs, the standard float chamber vent is a couple of slots cut into the top center flange. There is a sheetmetal cup with a side cutout that fits between the flange & the top hold down bolt. This cup is a larger diameter & allows vent air to pass into the float chamber through the slots.
There is also another type of vent that consists of a banjo with vent tube. The top is not slotted on this type of carb. The banjo is sealed to the float top opening with a special washer that has scalloped cutouts on it's inside diameter to allow air flow from the banjo to the lid. The top of the banjo is sealed to the bolt head with a standard fiber washer.
The float bowl attachment has several variations. They have different attaching bolts. The first type uses a brass washer with a fiber washer on each side between the bottom of the float bowl & bolt head. It uses a fiber washer between the bowl & the carb body.
The second type uses a different bolt with a steel washer & a shouldered Neoprene washer on the bottom of the bowl & a shouldered Neoprene washer between bowl & carb.
There is a third type that has a sort of headless bolt or hollow stud, threaded on both ends. This type uses a nut on the bottom, a steel washer next, & a shouldered Neoprene washer on the bottom of the bowl. Top of the bowl to carb has a neoprene washer & steel washer. The very top of the stud is sealed to the carb with a fiber washer.
My particular H6 carb uses the second type. No other arrangement will work. If you have the first type, the Neoprene washer will not work.
I have attached a diagram of the float bowl attachments.
Gray_Cat
Gray_Cat
Many thanks Dave. Your response answered my questions really well and I feel a lot better about working on the carbs. As far as I can tell the float bowls on my Healy attach as you describe in the first illustration. Also, the caps are missing for the float chamber lids so I will track a couple those down as well.
Thanks again!
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
J 100 bn1/bn2 id Austin Healey 26
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
pan Austin-Healey 100 BN1 Gears Austin Healey 5
Bob McElwee 100 BN1 Prototype Austin Healey 3
L Why won't my steering wheel turn on my 1954 100/4 BN1? Austin Healey 14
L 100 BN1 Tuning instructions ebay Austin Healey 3
simon1966 Leaf Spring Refurbishment 100 BN1 Austin Healey 3
bighealeysource Help with installing new top on 100-4 BN1 Austin Healey 4
bighealeysource nut for pulley on water pump of 100-4 BN1 Austin Healey 7
bighealeysource oil filter assembly on 100-4 BN1 Austin Healey 6
bighealeysource steering box and distributor question on 100-4 BN1 Austin Healey 7
Z 100/4 BN1 Harmonic Balancer Austin Healey 8
LuckyLuke BN1 -100/4 information needed Austin Healey 8
LuckyLuke Parts book BN1 100/4 for orig. fastener selection Austin Healey 5
LuckyLuke Dual circuit brakes for 100/4 Bn1 Austin Healey 16
Z 100/4 BN1 radiators Austin Healey 3
1 100-4 BN1/BN2 Drivetrain wanted Austin Healey 0
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
R Things to look for when buying a 100-4 BN1 Austin Healey 17
D 100 BN1 Clutch Austin Healey 5
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 7
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 10
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
3 100 Clutch Freeplay Austin Healey 7
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
