TR6 1976 TR6 Clutch & Brakes
Don_Houston
Thanks for all the help so far. I have have been refurbishing the 76 TR6 I got about a month ago. 23k miles, sitting in a barn for 30 years.
I have:
- refurbished the radiator, changed all hoses, belt (yes, I had to remove the cross brace, thermostat, flushed engine.
- Had gas tank professionally cleaned and coated inside and out, replaced the fuel lines, filter and pump.
Questions:
1.) There are two holes in the spare tire pit towards the front of the floor. Should these be plugged or left open for condensation to drain out (the trunk is immaculate)?
2.) The clutch pedal does not move at all. The fluid cylinder had a dry powder in it. What would be my next step to figure out what I need to clean, rebuild or replace?
3.) I flushed the brake lines and they seem clear. How do I check out the master cylinder to see wht it needs? I don't know yet if I need to completely change all of the brakes themselves or is this pretty much inevitable?
Thanks a million
TR3driver
Great Pumpkin - R.I.P
After 30 years, just plan on rebuilding or replacing all of the hydraulics, including at least the soft lines. Even if they work at first (which is unlikely), they will fail soon IMO.
On the clutch MC, remove the MC and see if the pedal moves once the MC is disconnected. Probably it will, but if not you'll need to work on the pedal pivots as well.
Just to give you an idea, here's what I found in the clutch slave on my "barn find" TR3:
The other cylinders were just as bad (at least the ones I was able to get apart).
hondo402000
sounds like the clutch cylinder has bit the dust, no pun intended, I would replace it and the slave cylinder, or at least take them apart but they are probably beyond repair, also I would replace that plastic tube to the slave cylinder with a Braided SS one,
Brake, might be worth pulling each caliper off and rebuilding and grease the wheel bearings, and do the rear cylinders too, the Master cylinder could be ok but I dont play around with brakes. Also if you have a PDWA I would take it apart and clean it and put new o rings in it too, then the brakes will be like new again
good luck
Hondo
tdskip
Hi Don - welcome.
There should be plugs in those openings in the trunk.
As suggested above, I'd plan on replacing the masters, clutch slave, cylinders and lines. Not hard to do and the right approach for safety and ultimately minimizing time spent etc. Just order from Moss etc.
Keep us posted on how you get on with her!
Don_Houston
Yesterday I attempted the first start-up in 30 years. Using starter spray on three starts (to pull the first fuel into the system?) it stayed running and leveled out at a nice idle.
Then I could walk around the car and noticed fuel coming out from under the emissions carbon canister. I checked all of the hoses there and tried again. Looks like the fuel is coming out of the anti run-on valve. I have previously completely replace the supply and return fuel lines.
I have not touched the carbs at all. Any ideas on root-cause?
Exciting day nonetheless.
Thanks!
TR3driver
Most likely you have a float valve that is not shutting off the flow of fuel. Could be a tiny bit of crud caught in the valve; or the float is not floating as it should. Might even be too much fuel pressure if the pump has been replaced recently. At idle, the float bowls are vented to the carbon canister, so the fuel is running through one or both vent lines and down through the carbon to drip out the bottom.
Most of the original plastic and rubber used in the fuel system will not stand up to modern 'oxygenated' fuel for very long. I'd give some serious thought to replacing the fuel pump diaphragm and carb floats.
B TR6 TR6 1976 Clutch Choice Question Triumph 3
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
D TR6 1976 TR6 Brakes and Clutch Triumph 0
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
TR6BobNF For Sale 1976 TR6 Engine Triumph Classifieds 1
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
D TR6 1976 TR6 Black Painted Parts Triumph 2
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
D TR6 1976 TR6 Seats Triumph 4
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
D TR6 1976 TR6 Fuel Lines Triumph 7
D TR6 1976 TR6 Rebuild Triumph 11
M TR6 1976 TR6 Ignition problem Triumph 6
S TR6 Paint in a 1976 TR6 Triumph 8
T TR6 Tire Preservation Question - 1976 TR6 Triumph 13
T TR6 1976 Triumph TR6 For Sale in Classified Section Triumph 0
BillyZ TR6 1976 TR6 Ignition warning light Triumph 17
P TR6 1976 tr6 specs Triumph 3
B TR6 1976 TR6 For Sale Triumph 2
L Spitfire New Acquisition, 1976 Spitfire Triumph 5
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
A Wondering about buying a 1976 mg midget will it smog? Spridgets 8
E New London Taxi Owner 1976 FX4 Other British Cars 1
B For Sale 1976 MG midget MG Classifieds 0
RickB MGB 1976 MGB with OD and factory hardtop - one owner MG 4
R MGB 1976 MGB for sale MG 0
K 1976 BMW 530i Other Cars 3
DrEntropy MGB 1976 MGB Roadster for a patient. MG 2
B Wedge Help 1976 TR7 Rear Brakes!!! Triumph 11
D Spitfire 1976 spitfire rear bumper question Triumph 3
ArcticOne Spitfire 1976 Spit in Southern Alberta Triumph 0
T Wedge Wedge deal alert - 1976 FHC project Triumph 7
R MGB 1976 MGB restoration question MG 11
bighly 1976 Midget Motor mount brackets needed Spridgets 0
M 1976 still won't start Spridgets 4
L MGB 1976 MGB - $500 [Santa Clarita] MG 1
J TR6 Need front bumper for 1976 TR 6 Triumph 6
J MGB 1976 mgb backfire MG 5
AngliaGT 1976 Triumph T140 Article in 11/07 Cycle World British Motorbikes 5
AngliaGT 1976 Bonneville - Anyone Interested? British Motorbikes 0
Bret 1976' Porsche 911 Targa Slantnose - Real or Not? Other Cars 14
E Wedge 1976 TR7 Victory Edition on eBay Triumph 5
