dklawson
Headlight relays are really a good addition. They take most of the load off the original switches and generally result in brighter headlights... especially if you switch to halogen sealed beams. There are kits our you can make the assembly yourself, neither is difficult to install. Take a look at the kit at AdvancedAutoWire.com
They include a schematic online that shows the connections. The schematic would allow you to make your own kit if you are inclined to do so.
https://www.advanceautowire.com/
(Click the link on the left for "headlight relay kit" for both the kit and its schematic).
A similar kit is available from Victoria British as a "heavy-duty headlight wiring harness".
https://www.victoriabritish.com/icatalog/sm/full.aspx?Page=121
And again... from Moss
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=104060&SortOrder=10
