TR4/4A TR4 Starter
KVH
I'm having mine checked at the shop. If it needs any work, should I just replace it with a high torque reduction starter. Sure looks smaller and easier to handle.
Kleykamp
Depends on how concerned you are with staying original, but I have used the high torque starter on each TR3 I've had and believe it is much better for a driver car and is something that can be reversed if someone really wants to go to "original". Shop around for best price. What I have seen, is most are remanufactured units that are just modified to fit and not much difference in the service you get. They are definitely easier to install.
TR4nut
I agree, it is a reversible option and other than originality I don't see an issue. It will sound different when you start the car up, but other than that they work well.
Geo Hahn
What was wrong with your starter? Over the years I have reworked mine a few times -- brushes, pinion rubber (TR3A only), clean-up and re-wrapping the field windings (they can short out after many years of rubbing against the housing.
The original units are pretty easy to service and when in good nick start the engine just fine.
I'm guessing you're having Luna take a look at it.
TR3driver
Great Pumpkin - R.I.P
I agree with all of the above. When I found that I was having to work on the original starter (on my TR3A) almost every year and it twice quit during long drives (each 2000+ miles round trip); I bought a gear-drive from TRF. Their ad said it was new, but what I got had a "rebuilt" sticker on it. Works great, although after nearly 10 years of daily driving (not counting the few years it was idle after the wreck), I think it may be ready for "freshening" again.
As a side comment, I changed the wiring a bit from the usual recommendation, so that the original solenoid only switches power to the new solenoid on the starter. That way the motor current doesn't have to pass through the original solenoid (which had previously lost some of its smoke), but the starter pushbutton (on a TR3) doesn't have to handle the increased current (and kickback) of the new solenoid, and I got to keep the function of the starter button under the hood.
The change was easy, I just moved the battery cable to the bottom original solenoid terminal (where the heavy wire to the starter motor goes) and ran a new wire from the top terminal to the solenoid on the starter.
Jerry
Just FYI, I just had one rebuilt and it cost $45. Looks like new again. I have not installed it but I am sure it works. I have taken a dozen starters, generators and alternators to this place and they are good with their work. My friends MGB starter cost more than that because it has a solenoid that needed to be replaced.
Jerry
KVH
KVH
Yes I'll try Luna before caving to a new one. I have a hunch I should've checked out my solenoid. I'll do that next.
Rrbbeerrttoo
Banned
Jerry,
Only $45 for reworking a auto starter equipment is cheap. Perhaps it was a friend who only replaced worn brushes , and sprayed paint! Even then!!
KVH
KVH
Just got back from Luna. The starter was fine. When will I learn?
The "new" shiny solenoid must be the problem. Either that or the ignition switch. Is there an easy way to test the solenoid?
TR3driver
Connect a voltmeter (or DMM set to volts) across the big terminals of the solenoid. Should read battery voltage, about 12.6 volts. Then use a temporary jumper between the battery terminal and the small side terminal on the solenoid, to simulate turning the key. Watch what the voltmeter does. It should drop to under 1 volt.
I didn't see a description of symptoms, but I would probably repeat the test with the voltmeter probes held directly on top of the battery posts. If it doesn't hold at least 9-10 volts while cranking (in warm weather), the battery is bad (or run down) no matter what the shop told you.
Geo Hahn TR4/4A TR4 / late TR3A Starter Pinion Triumph 4
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
Geo Hahn TR4/4A TR4 Starter Rebuild Questions Triumph 13
M TR4/4A TR4 Starter Triumph 1
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 2
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
