Play in steering
RickPA
Member
My steering has some play that I find annoying. With a 14 steering wheel it's about 1.5 to 2.0 inches of slop. When the car was restored I was told that the steering box did not need to be rebuilt but that they replaced the bushings. Nevertheless, I don't like the play. I was considering a Denis Welch column (STD) and also a new peg but, before I do, I'd like your thoughts on how to determine if I really need both.
thanks
Rich
steveg
Rich,
There's been a lot of discussion here of the DW boxes as well as the adjustment. Do an Advanced Search in the forum listed: "Austin Healey" for "Steering adjust" and you'll see a lot of threads.
For adjustment, loosen the big lock nut on top (3/4" IIRC) and lightly tighten the adjuster screw while moving the steering wheel back and forth from center until you can just feel the tight spot as you go past it. That'll be as good as it gets. This works better with the front end off the ground. You can use a coin in the adjuster screw.
I'd make sure the box is adjusted properly before considering the DW box.
See also threads on steering box lube, penrite and john deere corn head grease.
If you have to add lube, make sure you operate the steering lock to lock so it will settle to the bottom.
Edit: this is the most comprehensive thread: "Steering Box Replacement"...
http://www.britishcarforum.com/bcf/showthread.php?116063-Steering-Box-Replacement&highlight=steering
RickPA
RickPA
Member
Thanks guys. Over the years I tried using the adjuster with no improvement. When I did reduce play at the center the steering bound at lock. However it was so long ago I don't remember if I raised the car! So, that will be the first step and I've ordered some Penrite lube in case the resto shop didn't use decent lubricant although, as I mentioned, they said the internals looked OK. (So they say)
If all that fails I'm considering the steering column from DWR but dread the thought of shimming and the like. I'll do it as the car is now a family "heirloom" but I'm more vintage than the car is and my parts are wearing too.
Appreciate the help.
Rich
John Turney
.... However it was so long ago I don't remember if I raised the car! ...
Be sure to put 2" blocks under the upper A-arms when lifting the car so the front suspension stays in its normal ride height. As you tighten down the adjustment screw, move the steering wheel back & forth to make sure you are at the tight spot in the center and it doesn't bind.
Please let us know how that goes.
steveg
Or put jackstands under the spring pans.
mgtf328
I've have an AHspares box in my car. DW had stopped selling them for a while when I did mine a couple years ago. I've heard read on this forum that they've been having problems. Anyway, even if you change it you won't eliminate the play altogether. I have about 1/2" in mine. If I tighten it any more I can get it down to about 1/4 to 3/8, it still self centres at that but it gets a bit heavier on the arms!
AJ
RickPA
RickPA
Member
Maybe a little late in the game but how are you all measuring play? I measured at the wheel rim on a 14 inch wheel.
steveg
Rick,
We're all measuring play like you are.
Don't forget to observe your tie rods and idler.
With the wheels on the ground, have the assistant move the wheel back and forth for the play per above. My idler was moving up and down. Turned out I needed to remove a paper shim from the top cover to delete the play. Or maybe you've got worn tie rod ball joints.
If those are all perfect and the box is adjusted at the tight spot, then the play is in the box itself.
I called a friend who has a DW box and he says it has hardly any play at all, like AJ's above.
I rebuilt my box with a new DW worm and was not able to get better than about 1-1/4" play. I was lucky and had 3 other boxes from my mechanic that I could pull the best parts off.
If I had it to do over, would buy a new box from DW or AHS.
RickPA
RickPA
Member
I'm realizing that whoever put my car back together after restoration wasn't the greatest. I checked the adjustment on the box and snugged it up some. There is a noticeable drag at straight ahead now. Not a lot but it took some play out. While jacking the car I noticed the bumper bolts and overriders needed tightening. So, with that in mind I'll be checking the other steering components tomorrow.
Steve, I appreciate the comment about replacing just the column and still having play. You may have saved me from a futile effort. Hopefully, the weather will cooperate tomorrow and I can test my adjustment.
Rich
steveg
Rich,
Others may differ, but if you snug everything up and have 1" - 1.5" of play, IMO this is decent for a stock box.
When you're checking the play, remember to observe the front wheel - during part of the play it will move very slightly. How much play do you get before it moves at all?
I'm not a woodworker, but if I had those long bar clamps, I'd be tempted to clamp the front wheels tightly then see how much play in the steering wheel.
PS - if you've discovered some loose bolts & nuts, time to check all the bolts on the front and rear suspension for tightness.
M T-Series TD/TF Steering Free Play Question MG 6
Walter74 Steering Box End Play Austin Healey 2
Jayplum TR2/3/3A Steering Box end play Triumph 6
doc50 Adjusting play on steering box? Other British Cars 5
K TR2/3/3A Checking steering box End Play? Triumph 5
TRMark TR4/4A Play in steering pinion & rack mount mod Triumph 3
I TR6 Steering wheel play Triumph 11
Tinkerman TR2/3/3A 1960 TR 3A excessive 3" to 4" steering wheel play. Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
T TR4/4A TR4a steering shaft play Triumph 21
T Question on play on steering column Triumph 5
L How much play in your steering? Austin Healey 13
D Steering play Austin Healey 14
Darwin Adjusting steering play? Triumph 7
A Any ideas on a steering box with less play? Austin Healey 8
6 Steering wheel play Austin Healey 5
R steering wheel play Austin Healey 2
M TR6 play in upper part of steering shaft tr6? Triumph 2
M TR4/4A TR4 Steering Rack - play Triumph 4
S Steering Play Austin Healey 8
R Midget steering wheel play MG 1
M Layshaft End Play Austin Healey 7
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
M T-Series MG TD 1st/2nd sliding hub end play MG 1
AUSMHLY 1st Motion Shaft Play Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
matmire 23d4 distributor clockwise play... normal? Spridgets 4
4tecdog Play in first motion shaft on BJ8 Austin Healey 3
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A Distributor drive shaft play Triumph 4
RAC68 Calculating Front Hub End-Play Austin Healey 32
D T-Series Let's play "What kind of transmission does this go in?" MG 1
A LOTS of wheel play Triumph 12
W 100-4 distributor end play Austin Healey 0
RJS Differential Play Returns Triumph 8
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
glemon Triumphs at Play Triumph 10
T Anybody Want to Play "Identify the Crud"? Triumph 2
lbc_newbie Let's play.."What's my car worth" Spridgets 13
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
Morris No wife, no kids.... time to play Spridgets 11
6 crank end play Triumph 9
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
T BE Phantom Rear Axle End Play Spridgets 0
pjsmetana New Lugnuts? Drive shaft Play? Triumph 7
T Play in gearbox input shaft Austin Healey 6
D first gear sliding hub play Austin Healey 10
6 End Play in BJ8 Idler Austin Healey 2
