MGB Early MGB engine compatible with later transmission
mallard
I'm new to MG's so please bare with me on this. I have a freshly rebuilt 4 synchro O/D side fill transmission with the closed bellhousing for the starter (no hole). I need to purchase an engine and found a 1965 5 bearing engine 18GB UH 5875 locally. This engine uses the starter that has the drive assembly that sticks out of the transmission tunnel. Will this engine be compatible with the O/D transmission that I have if I use one of the high torque starters and are there other complications that I need to worry about? Any concerns with the flywheel and ring gear, transmission input shaft and pilot bushing, bell housing mating up to the rear engine plate. Any help is greatly appreciated.
Thanks
Keith
bob67bgt
To put the earlier GB series engine up to a full syncro trans the flywheel backplate and starter need to be the later style from 68 and newer. The pilot bush is the same .
M
mallard
Thank you Bob for the information, I think I got this figured out.
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
P MGB Early MGB fuel tanks MG 4
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
Wirewheels MGB NEEDED: Partial B post for early MK I MGB MG 0
E MGB VALUE OF A EARLY 1963 MGB MG 4
B MGB Early MGB parts for sale MG 3
K MGB Value of Early MGB Hardtops? MG 1
PAUL161 MGB Wanted-Early MGB Banjo Rear MG 15
M MGB Early MGB door locks MG 7
1 MGB MGB: early or late? MG 7
M MGB Early MGB O/D transmission - Interlock arm? MG 2
G MGB Installing steel dash into early 70's MGB MG 9
R MGB Early MGB Seats MG 3
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
Steve_S MGB Free Early MGB Transmission MG 15
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
HealeyRick Early Healey History Austin Healey 2
