Austin Healey 3000 Cylinder Heads
BN6
Does anyone know the meaning of the numbers cast in to the Healey 3000 cylinder heads.
red57
The only two casting numbers I have seen on Healeys are AEC 721 and AEC 960
I also wonder if it is aluminum?
Dave
red57
Interesting, the thermostat area looks like the earlier AEC 721 so pre-dates the thermochoke set-up. Based on Healey history that would make it around '58 or '59 vintage?? Please let us know when you learn the backstory.
Dave
bob hughes
You say that the head is from a Healey, but lots of 2.600 - 3000 Austins, Wolsleys and Morrises shared the same basic engines and indeed through the ages the saloon engines have been used in the Healeys, modified of course.
Could the head be from one of them? or would the casting references be the same as the Healeys?
:cheers:
Dandare
Bob, all of the C-Series (4 main) saloons 2.6 or 3L used the 2 port integral manifold head as standard.
Danny
bob hughes
Danny, they did until the new head came out, now I don't know if there was a different pattern to the chambers in the head or what have you, but a number of restorers on this side of the pond use these engines to replace broken Healey ones.
:cheers:
Dandare
Bob, yes blocks are the same externally just different compression pistons. The saloons did not use the new 6-port head however in production. As you say many Wolseleys and Westminsters pillaged for their engines.
I was born & bred in London S.E.5. BTW. :encouragement:
Danny
Danny
While I cannot quote the passage, nor from which Healey Marque history book, I too am of the understanding that the detachable intake manifold was only used on the Healey sportscars.
bob hughes
Well, I must bow to the collectives superior knowledge.
Following some research I must say that I can only find 1 photo that shows the removable intake manifold on an A110, and that surprises me, as I know that I have read at least two articles where the Healey head had been adopted for the saloon cars, see extract of one source below.
The new A110 retained the same basic unit-construction chassis/monocoque as the original A99, but there was a 2-inch longer wheelbase (arranged by moving the back axle rearwards on its springs) which allowed modified wheelarches to be designed and more space to be provided in the back seats. Also at the rear was a newly-installed transverse shock absorber, between the axle casing and the bodyshell, to contain incipient axle sway due to all the rubber in the rear suspension linkage. After the first few months, power-assisted steering became optional.
The engine was significantly more powerful, with 120bhp, this being achieved by 'raiding' the experience gained with Austin-Healey 3000s and involving cylinder head changes, a different camshaft profile and a twin-bore exhaust system. For this
Ah well you live and learn
:cheers:
Dandare
Hello Bob, The cylinder head changes for the 6/110 & A-110 were in the form of an increased capacity integral inlet manifold...what is sometimes referred to as a big log head.
The cam profile was changed twice on the 110s and the twin-bore exhausts were put back to a single system.The conspiracy theorists would have it that BMC wre worried that the performance of this saloon car was getting too close to the Healey which was not good for sports car sales. In truth nobody really knows why BMC did the things they did!
I have read in a couple of magazines that there were a couple of farina saloons built up to Healey spec by the competitions dept. for use as rally support barges for works Healey crews.
Danny
Dandare
Here is an image from the Wolseley 6/110 MkII sales brochure. This along with the equivalent Austin was the last example of the 4 main C-series saloon. You can see the integral manifold head and the reversion to single exhaust system.
Another clue re the cylinder heads for these vehicles is the spec for carburetters, they have never used other than twin SU H4.
Danny
pan
I have always thought it curious that the “12 port” cylinder head was used only on the Austin-Healey when so many BMC “Sports Saloons” were powered by the C Series engine.
At the Goodwood Revival last year, an A95 was going particularly well against stiff opposition. I wasn’t too surprised to see that it was 3000 powered!
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Guido36 Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
C Austin Healey 3000 in Modsports Austin Healey 4
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 2
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
Tremelune Wanted Austin Healey 3000 with a modern engine Austin Healey Classifieds 0
pbraun For Sale 1963 Austin-Healey 3000 BJ7 Austin Healey Classifieds 5
crya For Sale 1964 Austin Healey 3000 Austin Healey Classifieds 2
S Michelin XAS tires for my '67 Austin Healey 3000 Austin Healey 16
R Repair a First Motion Shaft for a Austin Healey 3000 Austin Healey 7
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
S A $50 Austin-Healey 3000???? Austin Healey 4
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
apbos Austin Healey 3000 Hardtop SFO NFI Austin Healey 18
A Austin Healey 3000- head configuration Austin Healey 10
V Austin Healey 3000 Vehicle identification plate Austin Healey 7
A Looking into to buy a Austin Healey 3000 Austin Healey 5
AN6-TX New Book: Factory Original Austin-Healey 100-6 & 3000 Austin Healey 8
F Watch Bruno Sena Drive Austin Healey 3000 - The Classic Car Show on UK TV recently Austin Healey 1
F Carpeting Austin Healey 3000 1961 BT7 Austin Healey 10
G Common Years for Austin-Healey 3000 frames Austin Healey 5
Chuck9482912 Rust holes in engine of Austin Healey 3000 Mk II BJ7 Austin Healey 22
BOBBYR Austin Healey 3000 Restoration by Gary Anderson Austin Healey 21
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
L 1960 Austin-Healey 3000 on "Chasing Classic Cars" Tonight Austin Healey 3
N I am eyeing up an austin healey 3000 2+2 Austin Healey 19
Hot Wings 1961 Austin Healey 3000 BT-7 4 sale Austin Healey 10
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
AH67 Steel Louvered Bonnet/hood for Austin Healey 3000 Austin Healey 1
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
H Accessing clutch plate on Austin Healey 3000 BJ7 Austin Healey 5
H Wheight front shroud Austin Healey 3000+transport Austin Healey 18
F Is the Austin Healey 3000 a midengine design? Austin Healey 12
F Austin Healey 3000 Mk II Sales Brochure Austin Healey 19
K 1966 Austin healey 3000 Austin Healey 10
Johnny Austin Healey 3000 BJ7 gearbox rebuild Austin Healey 16
F 67 austin healey 3000 clutch problem FORUM Navigation Questions 0
