Engine timing
Bob Buxbaum
So, fully rebuilt 1976 1500 with a full complement of factory emission control garbage attached. The owner wants it stone stock. Factory time is 2 degree ATDC at idle. The engine starts instantly, idles beautify, and has the power band of an old tractor. The owner says that is how it has always felt.
Question -- can I SAFELY bump the timing a few degrees BTC to give a bit of help?
Does it have the original distributor and vacuum advance module?
At some point they were doing some crazy stuff with the timing for the sake of emissions. IIRC, it was required to keep the stock timing to work with the emissions stuff otherwise you'd get incomplete burn at idle.
B
Bob Buxbaum
I am well aware of the emissions issues. The question still stands -- can I SAFELY bump the timing a few degrees BTC to give a bit of help?
I do not know the answer. I suspect that bumping the timing might give it a bit of help, but at the risk of damaging the cat or over heating the cat. The 1500 engines have a pretty long stroke and I've always thought of them as just a low rpm high torque engine.
B
Bob Buxbaum
Umm .... no cat. Not a California car.
Only the 1975 cars did not have catalytic converters. My parts book puts the cut off at GAN6-166304
Does it have EGR valve still in place? What about the anti- run on valve? If those are missing, or are not working, then you are going to need to just tune old school and hope for the best.
Rhodyspit75
I run my 75 Spitfire at 12 degrees before TDC. With a pertronix module. It also has HS 2’s. And it runs great. It’s the same motor. If you are too far advanced you will get pinging under heavy load. Then you will need to back it off a little.
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
C Static timing before engine start up Spridgets 4
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
B engine timing Austin Healey 5
Jeepster Engine timing problems Austin Healey 51
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
F Engine timing Spridgets 14
H 100 Engine Timing Chain Tensioner Austin Healey 3
BOBBYR BJ8 engine timing Austin Healey 18
BOBBYR HD-8 carb tuning and engine timing Austin Healey 7
2wrench Simple yet important engine timing questions Triumph 11
wkilleffer Setting timing on 18GK engine MG 14
G Setting timing without cranking the engine.... Triumph 2
J ENGINE TIMING Austin Healey 6
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
