MGB Engine on the hoof - parts car comes home
drooartz
My latest acquisition, a 1970 MGB GT that I just bought from a friend here in Utah. She is the friend I sold the '67 GT to a few years ago. This GT was her first car from when she was 17 (she's my age) and was her daily driver for many years -- and it shows. The body shell is toast. If it was a roadster it likely would have collapsed by now. What it does have is a good running engine and an OD transmission.
My plan is to pull the engine and transmission, maybe do a light refresh on the engine (bearings?, rings?, thoughts?), maybe just use it as-is, and put it into my MGB so I can get driving it. This way I can take my time and rebuild the original engine that's in my MGB. The plan is to do this swap in the next few months so I can be driving the MGB this summer.
Once I have the parts I need (it has an aluminum bonnet that I'll keep as a spare as well), I'll try and part out the rest and then the shell will go to the great twisty road in the sky.
Bob Claffie
That body isn't toast. Here in New England that would be classed as a simple rehab with several more years of useful life.
drooartz
drooartz
Sadly it's much worse than it looks like in the pictures. There is not much left underneath - the "salt" in Salt Lake City is not just a name.
Platinum
We can relate, Drew. Lost too many cars to west Pennsylvania winter road salt. Mitsy's MGB engine and gearbox sit here yet, the body long ago went to make soup cans.
If you intend to rebuild the original engine for the roadster, just stuff the GT unit into it without doing anything to it. You can rebuild that one after you've got the original back in.
drooartz
drooartz
It is a sad thing, but my friend got a good number of years out of it, and now the engine will live on.
I think that's the plan for me, Doc. Lob the GT engine into my roadster and sort things out when I have time.
Rut
I would do what Doc suggests and then start deciding what to do with the rest of it. It looks like there are lots of good parts left to salvage, but it’s hard work to part out a car and sell/ship and it cuts into your time that could be spent working on the keepers. That said I’m one of ‘those people’ who pulls them apart, refurbishes each part and puts them on a shelf just in case!
Rut
drooartz
drooartz
Even though I have lots of storage space, I'm trying hard not to packrat too much stuff. There is good stuff to pull of this car, so I'll grab what is most useful to me and then give or sell off the rest. Money's not the big driver, just don't want useful stuff to go to the dump.
I should have my current 2 projects (Morris suspension, Bonneville full service) done in the next month, then I will focus on the engine swap. Want to be able to put some miles on the B this summer, it's been too long. I bought the B (the first time) 7 years ago right about this time of year. I've had it back in my possession for 2 years, but really haven't driven it. Will be nice to spend some time, top down, on the local twisty roads.
And with the B running and the Morris and Bonneville sorted I'll be able to turn my attention to the Bugeye -- that's the big project for sure.
Mickey Richaud
You're probably aware, but those rear bumpers command a nice price!
drooartz
drooartz
The recessed grille (complete with bonnet finisher) does as well. The one on this car is a little messy, but it is complete and ha the bonnet strip. I'll have a few things I can sell from it to recoup a bit of the purchase price. Not likely to completely part it out, takes too long, but a few of the key things will get moved on. Don't want anything useful to go to the crusher if I can avoid it.
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
J Engine Parts Suppliers Austin Healey 6
