SteveBones
My problem is with my 1958 TR3A hood. At approximately 1200 to 1500 rpm there is a rattle. Looks like the previous owner removed the felt strip that fits between the support bracing and the hood. The bracing is located toward the back section of the hood closest to the air vent. I can press down on this section of the hood (back edge) and the rattle stops. When I remove the pressure the rattle noise returns.
I purchased and installed a felt strip between the support bracing and the hood. This did not fix the rattle. Any suggestions would be helpful. I can post pictures that show the area I am referring to including the felt strip if needed.
Thanks,
Thanks,
