Paint !
Bob Buxbaum
With the engine out of the 76 Midget, I cleaned up the engine compartment. Seems that the fine folks who built this car put paint directly on bare metal along the frame rails !! Anyway, I know the paint code, but do NOT know if this is lacquer.
Anyone know what type paint was used on these things?
I'd guess that it was acrylic enamel in the 1970's.
I would spray it with a single stage urethane.
Jim_Gruber
Speaking of paint, anyone got a source for OEW in Rattle cans. Need to paint my engine compartment while engine and tranny are out of the car. Or the paint code for OEW or the Porsche Equivalent Ivory Elfenstein or whatever it is called.
HealeyRick
Call your local auto body/paint supply shop. Many of them have the capability of filling aerosol cans to your paint code specs.
B
Bob Buxbaum
I have heard from restoration shops in the UK and stateside. They have said lacquer. So, I am going to lay down some clear stone chip, brush it smooth (as needed), and spray single stage rattle can enamel.
Did these restoration shops know you were asking about a '76 midget and not an early Midget?
Gerard
Porsche "Ivory Elfenbein" is supposed to be a dead match.
OEM Code 132L132
Brand Code 81137
Mixing Scheme: Concept (DCC)
(3rd time I have posted this)
B
Bob Buxbaum
Gerald, tanks for the follow up.
There is a regional automotive paint distributor here in the midwest called Color Vision. I have purchased rattle can paint for E30 and 36 BMWs from them and they always nail the color. So, after finally determining the actual color name (Brooklands Green) and code, they said that they had the formula for it. So, I now have a spray can of single part acrylic enamel. Two MG restoration specialists (one in England and another in Florida) indicated that the car was originally painted in a type of lacquer. Since the new paint will not be friendly to the old, I will be using a thin coat of clear chip guard as a cover and then lay down the spray paint. Since this will be only in areas of the engine compartment (mainly to protect metal that was exposed when I cleaned off all of the grime), this should be sufficient. The heater box / battery bay are surface rusted, so a coating of rust neutralizer followed by a thin coat of undercoat to protect that.
p.s. --- you have a PM.
I pulled an an old panel (from a late 60's) car with original paint. It does appear to be an acrylic (synthetic) lacquer paint.
Jim_Gruber
Thanks Gerard, But this is the first time I copied the information down and stored it where I can find it.
Gerard
Why do you think I mentioned it otherwise?... :highly_amused:
In the meantime, I can't remember where I put the touch-up bottle with the code on it... had to search for my own post so I could find the info!
Jim_Gruber
Interesting in that when I querried Ivory Elfenbein in Google, looking for paint, it came up with 3 references to your posting in BCF
SaxMan
I've used www.automotivetouchup.com -- they have some really good paints. I know they have the Glacier Blue for my '69 Sprite in their inventory. When I queried them about paint for my '53 Plymouth, they said they could make a batch for me, I just need to contact them directly versus purchasing it on the website.
B
Bob Buxbaum
Progress
B
Bob Buxbaum
I have another picture, it's an "after" picture.
nomad
Wow, I was not aware that the later midgets were that much different under the bonnet. Looks like a pretty solid car.
Kurt
B
Bob Buxbaum
Being a garage kept 15,000 mile car, it is absolutely rust free (except for some light surface stuff in the engine compartment that is been treated). A previous owner had the car resprayed (quite nicely, too) to a darker shade, but outside only. The convertible top is original, and in excellent shape, but has "shrunk" a bit. I FINALLY got the top attached at the windshield and snaps, but that was a bit of a war. So, other than the engine issues (in another thread), various hydraulic issues exist, but are simple fixes. Assuming the block is good, it could be running again next week.
JPSmit
sounds good - and with a bit of warm sunshine there is a good chance the top will stretch into place.
A Paint Color Codes Austin Healey 0
E TR6 Topaz (84) Paint. 84. Triumph 3
B Cove Paint Color Ideas Austin Healey 10
L Removing Master Cylinder Without Paint Damage Austin Healey 27
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
B 1977 Midget - Sandglow Paint Restoration & Tools 3
B TR6 Help with color and color code / paint recommendation Triumph 4
HealeyPassion Finally, paint on chassis Austin Healey 17
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
K TR6 Need help with Mimosa Yellow Paint Triumph 1
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Bayless A Sprite gets some paint finally Spridgets 2
D Body/Paint Shop Recommendations Austin Healey 1
BoyRacer Rattle can Healey Blue paint Austin Healey 2
Bayless More Paint Other British Cars 3
algot1901 Paint Other British Cars 15
BobHaskell "paint" thickness tester? Restoration & Tools 9
algot1901 1950 Ford Prefect Paint Other British Cars 5
Joel Lester TR2/3/3A DIY paint job? vs leave it to the professionals? Triumph 27
EWD TR6 TR6 top dash trim paint Triumph 2
somewhatspritely The black paint on replacement panels. Restoration & Tools 7
GeorgeC OK to paint battery? Spridgets 9
J Opalescent Silver Blue paint code Jaguar 0
Vargus TR2/3/3A what primer / paint ? Triumph 9
T TR4/4A Fenders off the car for paint? Triumph 8
B TR4/4A Wheel Paint Triumph 17
B TR6 what paint to use? Triumph 7
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
D TR6 Valve cover paint Triumph 5
TomMull Paint over galvanized parts? Restoration & Tools 8
Sopwith_Camel MGB-GT lick of paint 1 2 3 MG 2
Rut MGB Pale Primrose touch up paint MG 4
J Paint code Spridgets 0
J 1960 Bugeye Paint Codes Austin Healey 1
J Paint code Austin Healey 4
M Old English White Paint Code for early BE Spridgets 1
J Flaking Paint Inside Differential Austin Healey 6
C Under boot and under bonnet paint? Austin Healey 7
T TR2/3/3A Chassis paint color Triumph 10
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
vette MGB Paint Code MG 8
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
B Engine paint Austin Healey 17
D Lotus Elan S4..Bodywork evaluation..Strip & Paint? Lotus 10
P TR2/3/3A Chassis paint questions Triumph 8
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
