BT7 seat rails
  • Thread starter Deleted member 21878
  • Start date
Going to have to order new seat rails soon. Are there any threads I can read on some tricks to extend some leg room for the driver? I am 6-1 and although I have not sat in this car yet, I can sense there is going to be an issue getting my feet in the door when I get in.
thanks
Rob Glasgow
I am 6'3" and have never had an issue with leg room in my BT7 using the original location of the seat rails. Everyone is always amazed that I fit into the car.
I did have an issue with head room when the top was up and also seeing out of the windshield. I was always looking out the top one or two inches, just below the top frame piece. I solved those problems about 35 years ago by modifying the lower sear frames by moving the hinge bolt vertically about 2", allowing the rear sear back to recline several inches. Now with the seat slider in the rear most position, I have plenty of headroom and my view out the windshield is about 4" below the top frame piece. I've included a few photos. The metal piece is about 1" x 2-1/2" X 1/8" thick and is welded to the ear that held the original hinge bolt. I used a carriage bolt for the hinge bolt (same size of the original). Just last year I welded some additional taps to the rear of the lower seat frame to stabilize the seat back. Previously, the seat back only rested on the center tabs of the bottom frame. This modification made a huge difference in the comfort of the driving position. Not sure you can see the difference in the seat back angle in the first shot, but it's has a least 2" more rake than original.
vette
Drone Dog, I wouldn't use the ability to enter and exit the vehicle for your reference on positioning the seat, but what I would use is the extension and comfortability of your left leg when you use the clutch. My seat is in the standard location and with the seat slides all the way back I find it the most comfortable for my left leg when using the clutch. In actuality, I find that this position is a tick too far back for the most comfort of use with the clutch but if I move the seat up one notch on the slides then I am too close to the clutch and I feel that at the point where I am slipping the clutch to get the car moving then my knee is too bent and it is not conducive to a smooth operation of the clutch. So having the seat all the way back is more conducive to being able to operate the clutch with just a minimal leg movement.
With the seat back as far as you can make it and still be comfortable operating the vehicle you will find that is also the best you can get for entry and exit. I have a C5 Corvette that is rather difficult to get into. And I have had friends say that is way too difficult to get into. (therefore they wouldn't own one). My answer is that it is not the getting in and out that makes the experience.... it is what happens after you are in it. :smile: Dave.
Healey Nut
Re Vette’s reply .
Remember its a sports car , you dont get in it you put it on !!!
Treat it like a pair of really nice fitted leather driving gloves once your in the car and put them how you get in and out of it is really irrelevant.
Rob Glasgow
This post got me thinking about how I enter the car and although I've been doing it for over 50 years, I had to go out at try it. Open door, right leg in, holding onto wheel and rear fender, swing butt into seat and pull left leg into car. When I was 17, I could jump over the closed door and maneuver into the seat, looking quite dashing, a la Le Mans 24 hours. Now I think long and hard about taking the car out to do errands, counting how many stops I have planned and how many times I'll have to get in and out. 3 or 4 stops and I'm taking the Healey, more the 6 stops and the Pickup looks pretty good.
yes those knees do not bend quite like they used to. on the TD i had, i used to have to grab the left ankle to pull the foot back enough to get it in. of course it was tight even once i was in that car.
my question here was based on what i have been able to try. my seat rails are in bad shape with broken studs on them so i can't mount them in the car. i also wanted to wait until i have the engine in to put them in anyway so i am not crawling over them. since i bought the car in boxes i have never sat in it or know exactly how far the seat goes back. but i figured if it was an issue, someone on here has come up with a trick to make it better.
i do like the tilted seat idea. one thing that killed my back on the TD was sitting up so straight. i may have to try that one after i get the seats in.
bob hughes
Rob
I am with you now except I have a right - my left hip is shot and I have to put a straight left leg in first, hang on to the windscreen side support with the right hand and hold the back of the seat with the left and easy my right leg in whilst sliding in. Before I had an ungainly technique of leaning on the trans tunnel and putting my left leg in followed by my right after I had sat down.
:cheers:
kozelding
I'm 6'3" and have come to actually like the driving position: there's adequate leg room (with the stock seating position), and a sort of immediacy of having a steering wheel only inches in front of you. No long-armed limp-wrist-over-the-wheel cruising.
Though, like Rob describes above, I do have to hunch to see through the windshield.... I've littered more than few hats on the highway stretching my back without a top up.
As for getting in, it's still easier than a modern Elise!
https://youtu.be/D8aJkf-VXio
D Rear Seat Side Panels, BT7 Austin Healey 3
R 3-point seat belts on late production BT7 MKII Austin Healey 7
7 Retractable seat belts - BT7 Austin Healey 8
Indnrdr BT7 Seat Belt Mounting Acorn Nuts Austin Healey 0
Lin BT7 rear seat fasteners and install Austin Healey 7
Lin BT7 rear seat fasteners Austin Healey 0
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
