TR2/3/3A Water pump problem
Got_All_4
Installed one of those up rated water pumps from Moss when I installed the engine. In the past i remember reading posts where there were problems with the pumps. Horror stories where pulleys were coming off and going through the radiator. Herd some strange noises under the bonnet tonight and was watching the engine run and noticed a pretty good wiggle in the water pump pulley. You can actually grab it and wiggle it and I din't notice the shaft moving ether. So the pulley must be loose on the shaft. Tried tightening the nut and it's tight. The pulley is the original that came with the car so are they compatible?. What could be going on?
DavidApp
I seem to remember a comment about the woodruff key being tight and not fitting well in some of the water pump shafts. Could the pulley be riding on the key?
David
DavidApp
I would take the pulley off remove the key and refit the pulley then check to see if you have the wobble. If it ids gone check how deep the key goes into the pulley. Did the key come with the pump or is it the original key?
David
charleyf
Definitely remove the pulley from the pump and inspect the SHAFT of the pump and then the inside of the pulley. I had one where the shaft was wallowed out by the loose woodruff key. Pump and pulley were both throw always.
Charley
bobhustead
Last summer I bought a new Moss pump. The woodruff key cut in the pump shaft was metric and smaller than the 1/8 original key and the corresponding slot in the pulley. Had to have the cut in the shaft machined to 1/8. Worked fine. While I repeat that we would not have these cars without Moss and such, they were absolutely no help on this.
Got_All_4
Got_All_4
Got it all apart today. The pulley was definitely walking around on the shaft. You can see the scuff marks on the pump body and the inside of the pulley. I'm so fortunate that I have this resource here but went to Team Triumph this morning and bought a new pulley and wood drift key. As you can see in the pics I had the same problem as Charley. The new key was larger then the shaft slot but fit perfectly in the pulley. However I didn't take mine to a machine shop I just used my Dremmul tool and my grinder to alter the shaft slot and key to fit the shaft. Took over an hour to get it perfect. Just for some piece of mind I epoxied the key into the shaft. All is running now. I figured out the clutch problem one another post.
DavidApp
Fitting that key is tricky as it is completely hidden by the pulley. Found how tricky when I spun the pulley and the key fell out. Probable worth checking hao far the pulley goes on the shaft without the key first so you can see if the key is holding the pulley off a bit.
David
M TR2/3/3A problem with pulley on new water pump Triumph 4
Zimmycobra Water Pump Problem???? Triumph 24
BabaKahawa Water pump problem Austin Healey 2
Tinkerman TR 3 New Water Pump Problem Triumph 7
A Finially--new motor started, water pump problem?? Triumph 27
K Water Pump Problem?? Austin Healey 29
Basil Got the new water pump in..but still have problem Triumph 7
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
T TR2/3/3A Moss uprated water pump Triumph 6
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
George Zeck Water Pump ? Spridgets 5
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
D TR2/3/3A TR3 water pump question Triumph 4
S For Sale BJ8 Water pump for sale Austin Healey Classifieds 4
Got_All_4 TR2/3/3A Water Pump "Here I Go Again" Triumph 61
G Water Pump Failure - Diagnostic Steps? Austin Healey 16
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
Gordon_Dedrick TR2/3/3A TR3 Water pump replacement Triumph 5
C Healey BN6 water pump and overheating problems Austin Healey 11
K TR4/4A Water pump and water pump housing bolts..... Triumph 3
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
histerical Water Pump Spridgets 1
D TR4/4A water pump mystery hole Triumph 6
T TR2/3/3A Water Pump Housing Bypass Triumph 11
B TR2/3/3A end of me water pump thread Triumph 2
B TR2/3/3A Replacement or rebuild kit for water pump Triumph 11
B TR2/3/3A Water pump color Triumph 4
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
