TR2/3/3A Panel switch restore?
PeterK
Contact cleaner and sweep the knob back and forth fully to aid the cleaning, spray again then blow out with air.
If it works, I'd leave it intact and not bother taking it apart.
You should be able to test it with an Ohm meter.
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
P TR2/3/3A TR3B Panel Light Switch Triumph 20
B Wanted TR3A Rheostat panel light switch Triumph Classifieds 4
P BUGEYE PANEL LIGHT SWITCH Spridgets 10
T XKE Series 2 Rocker Switch Holder Panel Jaguar 0
memphis Panel Switch Wiring 3000 BJ8 Austin Healey 4
Bruce Bowker 100-4 panel light switch Austin Healey 3
TimK Panel Light switch Austin Healey 11
C Panel switch positions Austin Healey 9
tony barnhill '85 XJ6 Switch Panel/Trans Tunnel Console Jaguar 9
AUSMHLY How to: Shead light over your panel switch Austin Healey 8
R BJ7 overdrive switch chromed panel nut Austin Healey 7
jhorton3 Panel Lamp Rheostat Switch Spridgets 4
Agrandshort TR2/3/3A Unknown part panel Triumph 5
D Older door panel clips Restoration & Tools 4
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
R MGB MGB Roadster Door Panel Speakers MG 9
5 TR2/3/3A TR3 fender patch panel question Triumph 10
KVH General Tech Seat Upholstered Panel Triumph 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
LAW75 Instrument Panel Lights Austin Healey 9
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
F Door Panel Hardware Austin Healey 3
BoyRacer Door Panel Measurements Austin Healey 3
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
B Two questions about Bugeye floor panel weld drilling Spridgets 15
M BJ8 Inner Body Panel Repair Austin Healey 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
vette MGB Rear Fender Dog Leg Patch Panel MG 3
T Interior Door Panel and Top Rail Austin Healey 3
D TR2/3/3A center panel indicator light color Triumph 10
69MGC MGC Replacing an Outer Wheel Well panel MG 3
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
HealeyPassion AH Carb Access panel Austin Healey 24
S Wedge TR7 fuse panel Triumph 8
BOBBYR Body Panel measurements and angles Austin Healey 6
B BN4 Longbridge door panel question Austin Healey 4
C Door adjustment after installation of new door panel? Austin Healey 9
C How to remove entire dash panel on BN6? Austin Healey 4
P TR6 Rocker panel hole Triumph 16
