#1 - you will never know exactly how messed up your carbs are until you take them apart.
I cleaned and soaked the Cold Start Valve, good think I did it since I didn’t even know that there was a spring in there and it was all varnished up and stuck shut. After cleaning it opened up and moves freely now.
When I reinstalled the cold start valve I noticed that the vent port prong wasn’t moving when the throttle and cold start valve moved, so I pushed a bit from inside and it sprang out. It was varnished in place as well – yikes.
