Ofcalipka
So I've been resurrecting this 1976 MG Midget that has sat at least since 2001. The fuel of course was bad so I siphoned it all out as much as possible refueled her with 92 octane and then proceeded to change the cap, rotor, wires, plugs, and all fluids. So I start her up and she runs a bit rough and I hear a strange noise from the valves. I take off the valve cover and find a push rod on cylinders 2 and 4 off. I honestly don't know how the poor thing started at all. Anyways I order new pushrods from Moss, as one bent, and a carb rebuild kit. I put the new push rods in and start her and she runs okay. It won't idle very well at all when cold and not much better when hot. I drove it around and it was ok but definitely not working at its best. So I go ahead and clean the carb, which was all gooped up with varnish, and install the rebuild kit. I put it back together and now the car barely runs at all. I think it is way too rich. The prior owner had thrown away the heat shield and the auto choke and rigged up a choke out of what is labeled the starter box in the Moss carb parts list. Now here is my question. How does one go about adjusting the mixture on this and do I need the auto choke or is the current rig okay, I live in a tropical climate, never really gets cold here. Also do I need to make a new heat shield out of sheet metal or is this okay without? Now before anyone states put a better performance carb instead there are 2 reasons I don't want to do that. 1 I want to keep the MG as original as possible and 2 I can't afford a new carb. Your help in this matter is greatly appreciated.
Hi Guest!
