Ofcalipka
Thanks,
But half the fun of having the MG is fixing it myself. Ron come out to the Independant Cruise night in Mililani on the 11th. As long as she is running at all I'm going and I'm bringing the MG. It's always fun to meet others with similar interests.
Status Update:
Okay I fabricated a heat shield for the carb out of some sheet metal and the repair manual said to measure the distance from the gasket on the carb to the float bottom at 16-17mm. I changed it to 20-21mm instead. I then put everything back together and started her up. I could get the idle down to normal but she is still running quite rich. I drove it around the block and it ran alright. Definetly better than before but still way to rich as it bogs a bit when I try to apply power to the wheels. Getting closer to it running right.
Status Update:
