yelsink said:
I'm with Dale, I think it's mostly hype. What's interesting to me is that the stories of cam & lifter failures started long before the ZDDP levels went down.
From the research that I've done, ZDDP levels started dropping in the mid 90's. About when OBDII compliance started. Camshaft failures in the V8 hot rodding crowd, with very high ratio solid lift cams started to become more commonplace in the early part of this century. Those also coincided with a large influx of Asian made cams and lifters. Then the ZDDP levels were dropped even more, early eliminated, which is when the lower ZDDP levels became more public knowledge. So cam and lifter failures really started after the ZDDP levels were lowered below the minimum levels that they are now citing for solid lifter cars and before the near elimination of ZDDP from the modern formulations. The hard to determine part is actually if the poor quality reproduction items from overseas are more a cause, or accelerated the wear from lack of ZDDP.
