ttrotter
Is this oil readily available and where ?
In the US, my local Advance Auto has it.
Hi Guest!
It's been both a education and roller coaster ride with this topic! Many thanks to all that took time to research this important topic. The question now remains, will folks simply run out and continue to buy oil products similar to Castrol 20w 50w at there local Walmart for $15 dollars per 5 gallon container or special order the new classic oils designed for our vintage engines at $80 plus tax per oil change? One note: Some folks refer to our Healeys having a 7 quart oil capacity, Maybe they Refering to a Healey 100 Four banger? I know my big Healeys take every bit of 8 quarts with a new filter.
drambuie;916299 Even though the BJ8 oil capacity is just under 8 quarts....I always end up pouring in the full 8 quarts which brings the oil level just a shade over the full mark on the dip stick. If you are only adding 6 1/2 quarts with a new oil filter to your BJ8 then you have been depriving your motor of 1.150 quarts of motor oil! If I where you said:There are TWO thinking schools-
on the AH 100/6 Longbridge
If people respects the dip stick line you will find a 6-6 1/2 Liter -if you cover the MAX writing on the dip stick
you find a 7-7 1/2 pint - I prefer to fill 7 or 7 1/2 Liter on my engine, level have a very little increase, but we have more warm dispersion(I have also the oil radiator MOD) and a little oil splash in the basement that can be help in the cold start and haven't contraindication, and we respect the builder indications
Actually for my second Oil change, I must decide the definitive oil for my car (I don't agree changes for the future)
I have selected 3 Full Synthetic SHELL - CASTROL - MOBIL 1 --all with 10W60 gradation
MOBIL 1 probably are the best, but actually I never find it in EU continental (only in UK)
I am very hesitant but probably SHEEL will be my choice-- any suggestion pls??
Early 64BJ8 phase1. 6 1/2 US Qts.Plus 4Oz ZDDP. Original dip stick.
Yes, ZDDP is old technology but so is the engine. I wont gamble with my 50 year old engine to save a few bucks once a year.
. Hi Rodger, I really don't see a need to jack up the rear of the car to drain the oil in a level postion with the front. Draining the oil with the car jacked up at the front or on a hoist in level postion will pretty much drain the whole sump as the drain plug is located at the most deepest part of the oil pan anyway. I have done it both ways with the same amount of oil drain. Just change your filter, add your 6 1/2 quarts of new oil as you always do, and start your motor until you get full oil pressure. Shut the motor off wait a few minutes and top off to reach the full mark on the dip stick. It should require 7.6 to 7.8 quarts to bring it to the full mark...with car sitting level. Now...you weren't jacking from the rear of the car to change the oil before where you? Nah.... Just kidding. Let us know your results ok!Is Tahoe Healey 64BJ8 phase1 and myself 64BJ8 phase 2 cars only guys requiring 6 1/2 US quarts for an oil change? I believe my dip stick is also original, correct. I believe the car holds 7.65 US quarts. I assumed some of oil was still in the engine, oil pump and not completely emptying from the oil pan. Maybe I'm not getting a full empty because I am jacking up the front of the car only to get under it?
Some are filling with 8 US quarts? Does the dip stick read past the max line?
Next time I do an oil change, I'll jack up the back of the car too, so the car is level and see if I drain that one quart I seem to be short when replacing the oil.
Cheers,
Roger
