  • This forum is expressly for posting articles, related in some fashion to British cars (the kind you might submit for a publication). You post an article is the same way that you might post a regular thread, but you understand the article:
    • Must be 500 words minimum
    • Must Include appropriate prefix
    • May include Pictures
    • May be edited or rejected by admin
MG Your Midget Electrical System Dies When You Turn on the Headlights
For artciles related to the MG
The car started and ran fine until I: Turned on the headlights, stepped on the brake, used a turn signal, or ran the heater fan. I asked Chat GPT what could cause it, and here's its reply (which was absolutely right!):
That’s a very classic electrical fault, especially in older British cars like your 1976 MG Midget. Based on your description:
  • Engine runs fine with ignition on.
  • Turning on headlights kills all electrics (ignition, lights, accessories).
  • Turning headlights back off restores ignition power.
This strongly points to a main power feed or ground issue rather than the headlights themselves. Here are the most likely causes:
1. Bad Ground Connection​
  • The battery’s negative cable should be bolted solidly to the body and/or engine block. If this connection is corroded, loose,or damaged, the system can’t carry the extra current draw when the headlights are switched on.
  • Result: turning on the headlights “starves” the ignition circuit, and everything dies.
Check:
  • Battery ground strap to chassis. (I started here)
  • Engine ground strap (from engine/transmission to body). (I did this)
  • Clean and tighten both ends. (I took a break here)
2. Faulty Power Feed or Connection at theSolenoid​
  • On MGs, the main battery feed often runs to the starter solenoid terminal, which then distributes power to the rest of the car.
  • If the connection there is loose or corroded, the extra load of the headlights can “break” the circuit and cut off all power. (This checked out okay)
Check:
  • Big brown wires at the solenoid and fuse box. (JACKPOT! The brown wire was wedged down against the chassis just ahead of the firewall. I will list the rest if your isn't fixed yet)
  • Look for overheating, corrosion, or a loose ring connector
3. Headlight Switch Short or Miswiring​
  • Less likely, but if the headlight switch or its wiring is shorting to ground instead of routing power, flipping it on could effectively “kill” the power bus.
  • This would also explain why nothing lights up when the headlights are switched on.
Check:
  • Inspect the headlight switch wiring for melted insulation or misconnected wires.
  • Trace the brown (always hot) and red (headlight feed) circuits.
4. Weak Battery / High Resistance​
  • If the battery is weak or a cable has internal corrosion, turning on the lights may drop voltage so low that the ignition coil cuts out.
  • But usually you’d still see dim lights, not a total blackout, so this is less likely than a bad ground or main feed.
✅ Most Probable Cause:
A bad groundstrap (battery to chassis or engine) or a bad mainpower connection at the solenoid/fuse box.
Best of luck to you in your quest. By the way, be sure your battery is fully charged.
