As I posted in another thread, my younger son's PT Cruiser has been misfiring badly, so I've lent him our Santa Fe while I try to sort out the issue. I had Auto Zone pull the codes and found it was misfiring on two cylinders. So the first thing I tried was to replace the plugs and wires (it was time anyway). Initially I thought that was going to fix the issue because it was running smooth right after that and the check engine light went out. So I took the car back to my son and thought all was good. The next day he calls and tells me the car is doing the same thing again. So I took it back to AZ to check the codes - same codes - same cylinders. Ah ha! It must be the coil pack going bad I thought, so I replaced the coil pack last night. No joy - same issue. After some internet sleuthing I am now leaning towards the likely culprit being a bad intake manifold gasket. Several people on forums described the same issue and that turned out to be the problem. (If not, my next option is the PCM - which I really hope is NOT the issue)
Replaced the intake gasket - again no joy.
I had the codes read again at AZ and this time, all the codes were fixed (probably due to new coil pack) except one. The #3 fuel injector was still showing bad. I pulled the fuel rail and did an ohm checks on all injectors and all were in spec. Next, I swapped #2 with #3 to see if the code would move. It did not. At this point, I convinced myself it had to be one of 3 things. Either a bad connector at #3, a bad wire harness elsewhere (in which case I was toast) or a bad PCM (computer). First I replaced the #3 injector connector. Nope - still bad. So now I could either assume the harness was bad or I had a bad PCM (computer). Before I ordered a new PCM I cleaned the contacts on the existing PCM and seated and reseated the 4 connector plugs several times hoping it was just a cruddy connector . No joy.
Ok, so last week I ordered a new (rebuilt) PCM for $337 from Flagship One. The come flashed and ready to insert based on your VIN.
The new PCM came today. I swapped it with the old one, and viola! That car is running like a champ - NO codes!
It was a bad PCM the whole time!
This has been a splendid read, with a joyful outcome to boot. A regular "Who dun it". Turns out the culprit was The Brain... lurking under the hood all along. Thank you for sharing the twists and turns. Kudos, elrey
