JamesWilson
Brosky said:Rubber fuel line and stainless clamps, but not for too long.
But maybe copper tube for more rigidity and a longer term DPO fix....
TheSearcherMan said:You are whinning about 20 bucks?
tdskip said:TheSearcherMan said:You are whinning about 20 bucks?
Yep - I am. Look, I have no problem spending the $20 bucks. It just seems expensive for what it is, and I thought it was a good opportunity to see what creative ideas the group has. I've learned to never discount the knowledge and creativity of the folks here!
...that would have been too easy...
). To remove the grill (necessary to check/change the air filter), the stupid little clip has to be pressed <span style="font-style: italic">through</span> the grill. A real PITA. And to make matters worse, the clips often break when doing so... naturally... These stupid clips were (AFAIK) <span style="font-weight: bold">only</span> used on the '72 and '73 Volvo 1800E/ES with the plastic grill. About 12K cars were made. Replacements are available.. for about $6 EACH. Needless to say, when I removed the ones from my parts car, they will be saved.Moseso said:Here's a picture of what I tried to describe last night. It's not flexible like the stock link, but I figured if one end was still in a flexible link, this would work. It did, till I put the new replacement flexible link in...
Moseso said:The stock "folded" links allow for less-than-perfect alignment of the two shafts being linked -- a good idea. My fix is less forgiving.
IanF I really hope that I can switch to a RatCo linkage and remove some. They just look weird. [/quote said:<span style="color: #660000">Hi IanF, I hope you are well.
RatCo linkage?? I was not aware.
I have the Ratco cable throttle system installed in
my TR and I like it alot. The downside is it incorporates
the original stupid folded carb linkage and it quickly
gets bent real badly.
Does RatCo make a carb linkage to go with the cable throttle?
I would like to know. How do I check?
thanks,
dale </span>
Tinster said:Does RatCo make a carb linkage to go with the cable throttle?
thanks,
dale
Tinster said:Hi IanF, I hope you are well.
thanks,
dale
