XJ40 Frul pump Replacement [again]
McKinley22
Greetings!
My name is McKinley, this is my first post. I hear that this family of British car lovers is one of the best places on the net to find help with Jaguars! I am sure some may know my situation. Just a few days ago a fellow member posted a topic about my Jag. We were wondering how the fuel tank came out of the trunk. After defeating that battle we came in to another. The problem is as follows...
I lost the retaining clips to the hoses that connect to the bottom of the fuel tank. Thus after replacing the fuel lines and turning the ignition the fuel pressure causes the fuel line to disassociate itself from the tank.
I know this is one of those problems that only happens to amateur mechanics like myself, however I am hoping that someone else may have some suggestion as to how keep the fuel line attached without those stubborn clips. I cant seem to find anything suitable with the exception of the original part.
In reality I'm not exactly sure how those clips work. How do they keep the hose attached with all of that pressure? It seems as though they just stay snug around the metal fitting of the hose. I can barely keep the pressure back when I'm holding the line in with my hand.
Any help would be appriciated. Thanks in advance, McKinley.
PS: Vehicle in question is 1994 XJ6. Vin 702xxx.
LarryK
I would find the one you lost or get on-line and order them or get to the nearest dealer and order them. To be safe with that amount of fuel pressure, better to be safe than sorry. XKS Unlimmited in CA, Welsh Jaguar in OH, Terry's in IL. are some sources.
bmurphy7369
McKinley,
Hello neighbor,
Glad to see you made it to the forum. The members here are very helpful, interesting people with a wealth of knowledge. I am curious as to the way the clips act as retainers as well, having had my hand on the hoses (with no view of them) it is difficult to say. Someone will be able to explain the setup to you.
I believe it was Larry who mentioned dropping the driveline... this must be the reason for Haynes recommending that procedure first. Larry, by the way, welcome to the forum and thank you for your help when I asked about the tank removal a few days back.
Hang in there,
The drive is worth the wait..
Brian
jessebogan
Try coventry west. They part out Jags as well as new parts.
1 800 331 2193
The clips go through a slot, and through another slot in the line. As this is a major fire hazard, I would suggest using the proper parts.
M
McKinley22
Thanks for all of your help so far. I am happy to report that last night I was able to get the hoses to stay put. I used a standard hose clamp that is working fine. I did not find any holes in the fitting that the original clip might go through, and I am pretty sure that I am not leaking any fuel. I drove the car for the first time last night, and have since driven about 40 or 50 miles with no problems to report. I have also emailed Coventry West (thanks Jesse) to see if they have the needed clips.
Thanks again,
McKinley
bmurphy7369
McKinley,
As you know I saw the car running today and it looks and sounds great! Come by when you can and I'll take some photos for you to use for your avatar or to post in the Member's Rides forum. Now we are back to only one dead white/biscuit Jaguar in the neighborhood.... that would be mine of course! Thanks for the offer to help and I'll take you up on it.
Don't forget to introduce yourself in the New Members Forum........
bmurphy7369
Exotexs,
You're right on the shipping. I needed a few emblem retainers for my car, and a $3 part purchase was going to be around $20. I think someone mentioned Engel or Ingel Imports recently, I think in Illinois, somewhere close to here anyway. I'll get their info. They seem to have alot of NOS Jaguar, but I am not sure about post-1987 supplies. The lady I speak with there did Moss's Jaguar XJ catalogue, obtained diagram print permissions, etc.. before going to Ingel or Engel. She was very sharp on all Jaguar questions I had, so they may be a place that can help with reasonable prices as well. Other than that, Tom Wood Jaguar in north Indianapolis may be an option, but the Jaguar contract with dealers only allows them to service cars and sell parts for cars that sre less than (?) years old. They had a gas cap in stock for my 1993 a few years ago, so give them a try. No shipping either, just a long boring drive from here.
Brian /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Platinum
Engle Imports, (800)-253-4080.
Used 'em for years.
bmurphy7369
Thank you good Doctor, I couldn't find it in my list... I need to give them a call soon as well. If you ever get a chance ask for the kindy lady that came from Moss Motors, she is great to speak with. She isn't normally in sales, but knows her cars inside and out. Are they in Illinois? or Iowa? Can't recall now.
Brian
equiprx
It's unlikely that the hose clamps you used will result in anything but a catastrophic failure. I can't imagine that your local Jaguar parts shop doesn't have them in stock since they were used on all cars from 1993 on to at least 96. You uninstall the clips by pulling them like a hand grenade pins. There are two sizes, large for the large hose and small for the small hose. You re-install the clips on the hose before you install the hose to the tank. The straight side of the clip goes through the slot in the fitting and the curved part of the clip rests around the fitting. You should use a vacuum grease or petroleum jelly on the NEW o-rings and fittings and the fittings will now just snap in to the tank.
Steve D'Angelo
Pacifica, CA 94044
1952 XK 120, 4.0 liter OTS replica
1994 XJS, 6.0 liter coupe
1994 XJS, 4.0 liter coupe
BritCarFan
I had to remove the fuel tank recently to replace the fuel pump. I did not remove the driveline, but getting thos clips out was a major pain. If the car has been raised up a little higher access greatly improves.
I would defenately replace those hose clamps with the proper clips as all the vibrations and the pressure will loosen them up and you don't want to get stranded on the highway.
The clips are straight on one leg and curved on the other. When replaced, just double check by pulling on the fuel lines.
F XJ40 3.6 1988 fuel injectors Jaguar 1
F XJ40 3.6 1988 mis_firing Jaguar 2
T Largest tire size I can put on my 89 xj40 Jaguar 1
BritCarFan XJ40, a sportier sound perhaps? Jaguar 1
BritCarFan XJ40 A/C is hissing at me! Jaguar 2
bmurphy7369 1994 XJ6 XJ40 fuel pump replacement Jaguar 6
Sprocket rear shocks for a xj40/ Jaguar 3
L XJ40 ABS Warning light Jaguar 0
J XJ40 Wanted Jaguar 3
J 89 xj40. rad fan. Jaguar 3
M Jaguar XJ40 Jaguar 1
H XJ40 vs Escort Jaguar 3
H XJ40 fenders Jaguar 1
J colour codes on xj40 Jaguar 0
AndreL TR6 Conversion to electric fuel pump Triumph 14
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
M 1500 Midget water pump weep hole Spridgets 2
Celtic 77 MGB Seized air pump issue MG 25
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
D MGB Fuel Pump MG 2
M Smog pump and alternator brackets Spridgets 0
Martinld123 Electric Fuel Pump Austin Healey 6
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
KVH General Tech Oil Pump Woodruff Key Triumph 10
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
NutmegCT Tire pump in reverse? Restoration & Tools 5
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
KVH General Tech Water Pump Triumph 3
A Spitfire Fuel Pump Triumph 5
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
T TR2/3/3A Moss uprated water pump Triumph 6
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
