I have recently discovered that both fulcrum pins are worn from the nuts being loose. I have yet to measure the amount of wear but I can see one of the threaded ends has damaged threads. The proper repair would be to cut out and replace the shafts but this is very invasive and requiring the engine to be pulled for welding access.
Has anyone else replaced these? If so what issues did you encounter.
Thanks in advance.
Thanks in advance.
