Working with clean parts is soooo very nice
tdskip
What started all of this;
And now ready to go back together (a-arms also powdercoated).
Will try the front suspension as a unit assembly path this time (thanks guys). If I can get her back together in the next couple of days (which at this point I darn well better be able to do) then next stop is to install the freshly rebuilt engine and O/D.
HerronScott
Very nice! Was it very expensive to get them powdercoated?
I remember how much time I spent sanding, prepping, primering and painting parts like this when I did mine. It took quite a bit of time and even then I know they didn't look as nice with my limited facilities and funding at the time!
Scott
mallard
Scott all the parts seen above would be $2.00 each to be blasted, powdercoated, and wraped. The time spent cleaning and painting would well exceed the price of powdercoating in my opinion.
HerronScott
Wow, really? I had no idea it would be that cheap.
Scott
Brosky
I wish it were that cheap around here!! But mine are done so why complain? I'm happy with them and you will be too.
rlwhitetr3b
Bronze
Is there a reason not to do the small stuff yourself? It is my understanding that it is not hard to do, but does require an oven that will reach 400 degrees.
DO NOT USE THE ONE IN YOUR KITCHEN!!
TR4nut
Keith-
I'm going to start mailing my stuff to you! Around here, the powdercoat place charges $225 mininum order, and that picture is maybe a quarter or fifth of a typical order. That powdercoating is beautiful, I would kill for a place that charged $2 a piece!
Platinum
Work clean.
Nothin' better.
mallard
Randy you may want to look into shipping the parts to Arizona Powdercoat. Shipping would be the killing point though I think. I just got back 13 parts last week from them for $26.00 plus tax. If you can get a bunch of parts in a flat rate box from USPS it would not be bad.
Arizona Powder Coat
5301 E Washington St
Phoenix AZ 85034
602 220 0553
I have no connection with them, I'm just satisfied with their work. I don't think they have a web site.
JodyFKerr
Wait a second here. :smile:
Did you sandblast/clean the parts ahead of time, or did you have them do them?
I think they may have just got a new customer as I'm only 10 or so miles away. :smile:
Jody
mallard
All you have to do is remove any soft material, sealant, undercoating. They will remove all the rust, paint, or any other material to bring it back to clean metal. I've even seen them do body parts.
Tr4dude
I wonder do they degrease or preheat the parts to remove any soaked in oils or grease, and do they use iron phosphate for corrosion prevention?
I am a powder coater and that is way cheap even for an hourly wage with expenses.
John Ruskin, Author - Economist 1819-1900
The bitterness of poor quality remains long after the sweetness of a cheap price is forgotten!
DNK
I agree, most shops that is way to cheap. My shop has a $150.00 minimum.
angelfj1
My modest set up based on the Eastwood system has payed for itself many times over. I can powder coat any part that will fit in a standard electric oven.
mallard
Sorry guys but sometimes cheap is a good thing. My TR6 parts were coated at the same place eight years ago and not one problem. Maybe the guy that did the billing made a mistake because the last time I was there they charged $3.00 per part instead of $2.00 this time.
My last big job they did for me that included the frame, and 95 other parts was $656.00 All of the parts were for the TR3 that I'm restoring now. The time saved was well worth the price alone.
Gee Wiz Tom I never did comment on your part of this post. Parts all look great, and yes it is nice working with clean parts. The only problem is that you don't want to bolt any dirty part to the clean ones. It's hard to find a good stopping point.
Frank I would love to invest in my own setup but I don't have the room. I bet you could do 95% of all the parts at home.
Tr4dude
They do look very nice!!! Once there installed you will say what can i do next!! Ask me how i know
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
D Trying to get back working on the 1974 Midget Spridgets 10
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A my OD stopped working after it was working Triumph 25
D TR2/3/3A Traffic at or and horn button not working Triumph 2
O Spitfire Tail lights not working Triumph 6
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
Celtic 77 MGB Non working tach. MG 4
M Tachometer not working following ignition upgrade Austin Healey 10
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
KVH General Tech Speedometer Not Working Triumph 5
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
S TR2/3/3A Speed O not working Triumph 27
M Wiper Motor Problem Not Working Spridgets 5
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
W Healey 100 Overdrive stopped working Austin Healey 15
1 MGB Lights not working MG 11
A MGA High beam indicator light not working MG 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
warwick-steve Direction indicators not working Austin Healey 29
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
Jim_Gruber Brake Light - Getting them working Spridgets 8
Superwrench Tach not working Austin Healey 6
M TR2/3/3A Panel lights not working........ Triumph 5
Rhodyspit75 Working on the Bugeye body Spridgets 19
J General TR D Type overdrive not working need suggestions Triumph 5
J Helping out some students working on a 59 bugeye Spridgets 6
R Master Cylinder change working Austin Healey 12
F Overdrive - working but not really working Austin Healey 14
T TR2/3/3A Air dam seems to be working very well Triumph 5
BN6_2197 BN6 brakes not working properly Austin Healey 9
bugedd Fuel guage not working Spridgets 7
Nelson Working under the car Spridgets 5
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
R Choke Not Working In Cool Weather Austin Healey 15
D new mecahnical fuel pump not working Spridgets 8
Gerry M TR6 Speedo stopped working Triumph 6
DanLewis Looking for an old-style fuel gauge [working or not] Spridgets 3
P I need a non-working electric tachometer for parts Spridgets 0
DerekJ Left side indicators not working. Austin Healey 3
G MGB STILL working on clutch slave MG 37
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
J Funniest thing you found working on your car Austin Healey 32
B Horn Quit Working Austin Healey 14
D TR6 Blower working! Triumph 3
