Wood convertible top bow- Is it covered or painted
vette
I'll have to look at mine, but off hand I think it is covered.
GregW
Platinum
Guess the next question will be "What Color" or is that colour? My BJ8, with a OEW paint job, has an off-white vinyl wrap on the wood.
shorn
The color is off-white to creme. i believe that British Car Specialists carries the correct vinyl, but I found mine at Phoenix upholstery in Vancouver, BC. I can recommend Phoenix for any interior work.
R
robert_ellison
Re: Wood convertible top bow- Is it covered or pai
Hi Shorn,,
Looking at your picture it's difficult to tell what (if anything) is painted or covered. In one set of instructions it says to cover the aluminum channel with fabric, you say the bow itself. Can you be a little more specific.
Also, if you have any pics of things like how the top is connected on the sides, or in the rear, or if there are some metal trim pieces at either side of the front bow, anything would be appreciated.
Thanks.
Robert
GregW
Platinum
Hi Robert,
Wasn't sure if you were asking me about more photos or Shorn. I don't have many, I didn't want to disassemble my top until I welded the wheel arch bases on. Here is one that shows the side from the inside. You can see where the wood is covered in the vinyl more clearly. The vinyl is the same color in the first shot I posted.
R
robert_ellison
Greg,
Thanks for the side shot.
Does anyone have any info re. actually replacing the top? I have gotten advise from Moss that it is so difficult I need to have a pro do the job. The quote I got was $600.00 for installation only. Needless to say, I would prefer to do it myself unless it actually is that difficult.
Appreciate the feedback.
Robert
shorn
The top is difficult to replace, but can be done. The problem is that if you make a mistake and make an incorrect cut, you have ruined the top. I had a pro do mine (cloth, rather than vinyl). He did a fair job, but I didn't think he stretched it well enough in back, so I worked on it myself. Not sure I would want to do the whole job myself. You would need instructions as to where to start, which I beleive is at the rear bow. I think the pros figure it is about a 7 hour job (thus the $600). If you do it yourself, make sure you know exactly how you took the old top off (how it was applied). Macgregor, in Canada, 18777776381, carries a correct replacement for the furflex/rubber molding that presses on the aluminum top pieces (not cheap, but a correct color).
Jerry
Does anyone have any more pictures of the wood pieces and how they fit vs the window? I was putting my wood pieces back on and wound up the window. The curved wood piece does not fit well againist the glass. Is this typical?
Thanks
Jerry
BJ8
Have installed two tops on two different BJ8s in the last two years. It is (to me) about the hardest job on the car, but can be done with patience. Recovering the wood pieces (I did black but original white vinyl)with the top took me three days on the last one. I bought a Kwik top last, will not buy another. Install top with clips pushed on just enough to hold top on the rail and sit in place to make sure you are even on both sides. After that it goes pretty quickly.
Marv
Jerry
I fitted two of the wood pieces yesterday but the curved ones don't fit so well, or it does not make sense how they fit. But I stumbled onto Andy's web site last night and it makes more sense. We bought the car all taken apart so I don't have pre- pictures. I noticed that the wood pieces don't follow the window when it is up all that well. It could be I don't have the metal frame into the right position yet.
Looks like a pain job.
Jerry
BJ8
Thanks for the help.
Johnny
Robert, I installed the Amco top on my BJ7 without too many problems. I agree with all the former posters. Study the photos carefully. Here's some other tips you might find useful.
Start by installing the webbing on the bows first. Don't glue the webbing as the site says. Lay the top on loosely and leave in the sun to warm up. Clamp the top to the front and rear, and the sides.
I started at the rear, centering the rear window against the metal frame. Actually, there was a weld their at center. Having the rear window in first helps to align the side portions. Don't cut any excess off the bottom of the top at this point. Just install a few clips to hold in place.
Stretch over the sides and clamp in place. You'll have to adjust the fit at the rear about 3 times before you'll get it right.
Don't screw the top onto the side posts until you install the rubber tips on the ends. Try rolling up the windows and adjust the side posts until they fit correctly around the windows.
Good luck. The job can be frustrating but really not too bad. Took me two evenings.
John_Progess
Robert,
I purchased the Moss video tape of interior installation for my restoration. It is a usefull tape and covers the top installation well although they did cover the top wood front rail in black. It is worth the purchase. Have a good day!
John
Griz Wood for convertible top Austin Healey 3
S Convertible Top Wood Strip Set Covering Austin Healey 12
A BJ8 Convertible Top Wood Source? Austin Healey 2
JohnGone MGB Wood Dashboard Kits MG 1
algot1901 50 Prefect wood roof support / bow Other British Cars 8
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
B Wood Braces, Hardtop Austin Healey 3
NutmegCT Exterior wood finish Restoration & Tools 21
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
L Replacing veneer on wood dashboard Restoration & Tools 14
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
Rut TR4/4A TR4 wood dash Triumph 26
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
R Wanted wood steering wheel Jaguar Classifieds 0
S TR2/3/3A wood next to the door on a tr3 Triumph 4
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Gliderman8 General TR Wood rimmed steering wheels Triumph 20
J TR2/3/3A Mystery Wood Triumph 7
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
KVH TR4/4A Refinish Wood Dash Triumph 7
P BN2 new wood steering wheel install Austin Healey 5
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
TomMull TR2/3/3A door wood Triumph 36
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
S TR2/3/3A beach wood- wooden handled screwdrivers Triumph 6
Got_All_4 TR2/3/3A Wood on frmes Triumph 11
J BJ8 Battery Support Wood Block is it 3/4" or 3", ours is 3"? Austin Healey 5
E Singer wood frame help needed. Other British Cars 3
J TR2/3/3A Wood strip in B post. Triumph 3
JimTR4 TR4/4A Does a 4 wood dash fascia fit a 4A? Triumph 2
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
J Wood dash for 60 BN7 Austin Healey 16
Jim_Gruber Wood Steering Wheels Spridgets 26
CJD TR2/3/3A Jacking Without a Wood Block Triumph 12
AHS TR2/3/3A Removing cowl wood? Triumph 7
GBRandy Jaguar XK 120 Dash. Wood or wrapped? Jaguar 4
Lukens TR2/3/3A Wood TR3 dash Triumph 10
J New wood pieces for the doors Triumph 9
hutten Wood steering wheel restoration vendors? Triumph 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
S REPLACEMENT WOOD DASH Triumph 12
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
Stinger TR4/4A TR4A Wood Dash Refinishing Triumph 18
5 Hardtop wood blocks Austin Healey 3
M need wood piece for convt top Austin Healey 1
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
CJD Door Wood Triumph 11
