Here's a few things to check, since I don't know what you did as part of the switch to a header pardon me if some doesn't apply.
1 Replace the condensor in the distributor, they can suddenly fail.
2 Did you remove the engine or any grounding straps while working on the car??
replace if you did.
3 Check the distributor cap for cracks/failure.
4 Are the valve opening and closing?? check clearances.
5 Fresh gas may help, modern gas doesn't react well to sitting longer than
a few months.
6 Got an extra coil around?? try swapping
7 I check plugs by putting one in the end and taping ot to the valve cover, shows what kind of spark you get following the path it will use when running. should be a bright blue spark.
These non computer engines are fairly simple, as long as you have fire, (spark), and gas, should at least occasionally fire. Provided of course the engine is in reasonable shape.
