Won't Start, fuel pump?
Crisis
Hello folks,
I've got a '65 E-Type which is fairly new to me. Today after washing car and after car sat on a downward slope (don't know if that could be a factor), she would not start. Clicking in rear which I assume is the fuel pump, won't stop clicking. I assume system won't fully prime and that is why it won't start? Any thoughts or suggestions?
Reid
LarryK
How full is tank? Was it sloped from pick-up. Remove drain plug and see if there is gas in it. This is assuming it has been driven previously and moved to slope on same day.
C
Crisis
Tank is full having filled only same afternoon. Actually had a nice drive prior to parking on the driveway with a forward slope. Went into the house, had lunch, came out and car would not start. Fuel pumped continues to click when normally it would only click once or twice, then I could push button to start. I took out the spare tire and tools, removed the cover panel over the fuel pump and could see that there was air in the line going to the pump; trying to pull the gas but didn't seem to have the prime. Make any sense?
C
Crisis
Thanks Larry,
Problem solved. Apparently these cars need gasoline? I took out the fuel gauge float just to get a look in the tank, and lo and behold, the tank was empty! I assumed the gas gauge was broken with and giving an empty reading even though the tank was full. Well the gauge wasn't faulty, the tank really was empty. I had been to the gas station earlier that day and thought I had just topped it up. In fact I think the pump (gas station) was turning itself off so I assumed it was full, when in fact it was nearly empty. Doh!
Thanks for your help anyway.
LarryK
Now you have a first to fix problem, welcome to old Jaguar ownership.
Happens to the best of us. Spent a whole eveing once with a frind trying to get a car running. He insisted it had a full tank of gas. Turned out to have a full tank, of air... Once a couple gallons were dropped in and the pump primed, started right up.
Geo Hahn
... In fact I think the pump (gas station) was turning itself off so I assumed it was full, when in fact it was nearly empty...
You should be able to tell when you have actually filled the tank -- you'll get 'see cashier' who will ask for either a 2nd mortgage or a spare kidney.
G Fuel Spark...still won't start ? Spridgets 17
B '66 Won't start maybe fuel pump related? MG 6
J MGB 1966 MGB won't start MG 1
B Healey Won't Start - No Spark Austin Healey 38
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
KVH General TR TR4A Engine Won't Start Triumph 34
C TR6 Zenith Strombers won't start when warm. Triumph 2
C Strange...can won't start and then magically ressurects Austin Healey 16
P TR6 Car won't start after backing out of garage Triumph 21
Tinkerman TR2/3/3A 1960 TR3A post 60000. WON"T START ???????????????? Triumph 8
J TR6 TR6 died/ won't start Triumph 30
P TR6 Won't start after 10-mile run Triumph 21
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
R No, it won't start! Austin Healey 8
M '61 BN-7 Progressively Harder Starting . . . Now Won't Start Austin Healey 9
P Car won't start Austin Healey 7
S 64 BJ8 won't start after 10 min. drive. Austin Healey 12
H TR2/3/3A TR3A Won't Start Triumph 15
E Help! Won't start Austin Healey 17
B oh crumbs! won't start! 79 midget Spridgets 12
KVH TR4/4A TR4A--still won't start Triumph 16
TulsaFred TR6 TR 6 engine won't start Triumph 4
mgbmedic won't start ...ignition? Triumph 2
C '72 Midget Won't Start After 2 Years of Storage Spridgets 40
I Bugeye won't start - help please Spridgets 22
A won't start Triumph 35
W Won't start Triumph 7
7 won't start Triumph 24
KVH TR4/4A TR4A Won't Start Triumph 30
S TR6 1975 TR6 won't start Triumph 3
D Engine won't start Triumph 14
Phil73 TR6 TR6 won't start Triumph 41
M MGB 71 MGB Won't Start MG 8
S 78 Midget won't start Spridgets 22
longbridgehealey Bugeye won't start Spridgets 27
M Won't Start-1995 Jaguar XJ6-Why Jaguar 8
W MGB-GT 1971 MGB GT Won't Start MG 11
Steve1970 Won't start if hot, suspect vapor lock, options? Triumph 7
M 1976 still won't start Spridgets 4
2wrench HELP! My car won't start. Triumph 65
H Won't start? Spridgets 16
KVH TR4/4A TR4A Won't Start Triumph 12
crya Now mine won't start! Austin Healey 9
tahoe healey She won't start Austin Healey 4
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
C Car won't start.... MG 14
J help-won't start Spridgets 16
M 87 Series III XJ6 won't Start Jaguar 16
tahoe healey she won't start! Austin Healey 14
B Bugeye won't start after tune-up Spridgets 17
