jaegzie
I was using a 63 wiring harness to get everything running properly on my BE, Now it runs good with this harness and everythig works. I want to put in the pull switch and basically make a wiring harness look like it was there. I have the wiring diagrams and everything basically laid out for what i need except for what gauge to use.
Is there somewhere that has these listed or is there just a standard for which gauge I should use or does it really matter, except for obvious spots where the gauge needs to be bigger like on starter, etc...
Thanks
Thanks
