MGA Wiring harness question
Coastalman
A friend of mine is clearing out bits and parts left over from a long owned British car repair shop. He called me today and asked if I was interested in a new, still in the bag, wiring harness for a 1500 MGA. I have a 1962 MKII that sure could use a new wiring harness. Does anyone know what the differences are between the two harnesses? I know Moss has different ones listed, but I don't know if parts or all of the earlier one could be used on my later A.
Thanks,
Charlie
Oriental, NC
C
Coastalman
Thanks Tom,
I bought the 1600 laminated wiring diagram and will compare it with the earlier one. I was just hoping someone knew if there was any major difference.
Charlie
bob67bgt
The later cars (1600) did not have the turn signal relay. The turn signal relay made it so you did not need a separate light bulb for the signals. Not interchangeable.
LarryK
If he is giving it to you, take it. Someone will need it and you'll have one. If he is selling it cheap same notion.
C
Coastalman
Thanks for all the information. My friend wants to sell it so I'll probably post it for him in the classified ads. He is just confirming the number with Moss and then will sell if for half price. It is still in the original packing.
Charlie
Bob Branson
Bought an uninstalled (and unlabeled) new harness for my 1500 and learned the difference the hard way It was for a 1600. The easy way is to check the number of tail light wires. You can use the 1600 harness in a 1500, but will have to fabricate wiring that goes to the turn signal relay, then tape off the unused third tail light wire.
barneymg
nichola TR6 Question on new wiring harness Triumph 6
ckeithjordan TR2/3/3A Wiring Harness Question[s] Triumph 10
Griz Rear Wiring Harness Question Austin Healey 6
B Question on OD wiring harness 57 Smallmouth Triumph 15
B wiring harness question: Triumph 3
Tinkerman TR2/3/3A Wiring Harness Question on my TR3A Triumph 8
Bone wiring harness question` Spridgets 1
bighealeysource BJ8 wiring harness question Austin Healey 8
M MGB 1970 MGB roadster wiring harness question MG 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
R TR2/3/3A Replace wiring harness in steering column Triumph 61
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
BoyRacer How to clean a cloth wiring harness Austin Healey 14
S TR2/3/3A installing the wiring harness Triumph 8
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
W TR2/3/3A New wiring harness Triumph 8
T TR2/3/3A Wiring harness Triumph 3
D new wiring harness Austin Healey 15
D 62 tri-carb wiring harness Austin Healey 10
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
SherpaPilot Wiring Harness for XJ6 Jaguar 1
tr3guy TR2/3/3A New Wiring Harness Triumph 7
MisterB How to spin engine sans wiring harness? Austin Healey 3
Rut TR4/4A Wiring harness female bullet connectors Triumph 6
Marvin Gruber BJ8 wiring harness install Austin Healey 6
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Rut 73 Midget wiring harness Spridgets 0
K TR2/3/3A Wiring harness "wire gauge" sizes? Triumph 20
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
K TR2/3/3A Wiring Harness Triumph 9
Got_All_4 TR2/3/3A TR3 A wiring harness Triumph 17
B TR6 Reverse light wiring harness routing Triumph 4
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
mt10flyer TR2/3/3A TR3 wiring harness Triumph 7
Rut Wanted, Bugeye wiring harness Spridgets 0
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Rut Bugeye wiring harness Spridgets 2
mt10flyer TR2/3/3A Winter Project-Wiring Harness Triumph 4
