TR2/3/3A Wiring Harness Question[s]
ckeithjordan
I’m installing a new wiring harness from Autosparks (in the UK). It’s really well-engineered and a work of art. So here’s my question (there may be others):
Should the leads to/from the regulator, solenoid and fuse box exit the main trunk of the harness from the engine bay side of the firewall opening, or be on the interior side, with the leads themselves passing through the opening? I’m aware that the other engine bay connections (brake lights, dynamo, horns, front lights, etc.) have to pass through as well.
sp53
From inside out, the difficult part is getting the grommet and wires through the hole. I used a funnel from the dollar store and cut that down to fit and fed them through.
steve
ckeithjordan
ckeithjordan
Thanks Steve. I didn't do a good job of framing the question. See attached photo of the harness. To the left is the bulk of the harness, ie, the gauge leads, tail lights, dipper switch leads, and the lead to the left-side of the engine bay (lights, wiper leads, coil lead, etc.). To the right is the lead to the solenoid, brake switch, lights, etc.). So, my question is should the firewall hole be at the left red line or the right red line? You can see that I've anticipated it being on the left, as I've squeezed everything through a grommet, which will line the hole. Is that the correct location?
sp53
Looks correct to me, are you going to feed the wires from the engine bay into the cockpit and then deal with the grommet? I believe I might have put the grommet in first and feed the wires from the inside out.
sp53
Something looks wrong, are you going to feed the wires from the engine bay into the cockpit and then deal with the grommet? I believe I might have put the grommet in first and feed the wires from the inside out.
ckeithjordan
ckeithjordan
I’m going to feed the wires from engine bay into the cockpit, the various smaller “limbs” are all smaller diameter and the grommet will be the last item in. I didn’t see how it was possible to to feed them the other way ‘round, as they were larger, plus trying to feed all those leads looked difficult. It’s interesting in that the grommet suggested has a smaller center hole; I’m using one of the frame grommets which has the largest opening and it’s snug around the harness at this point.
Thanks again for your help.
sp53
That area is tight with all the Y and using one of those other grommets might be great. I will try a picture but I am having trouble.
Anyways if you did it that way wouldn’t your gauge wires be on the wrong side of the firewall
CJD
If I remember right, the wires between the tie wraps are those going to the voltage regulator...so that would be outside the firewall, while the remainder goes inside. Is that what you are asking?
ckeithjordan
ckeithjordan
Yes. I looked at a lot of photos (including yours way back when) and couldn't tell. I assumed that they were, but then I thought, maybe not. The attached photos show where things go, as far as I can tell, I'm just looking for confirmation that the firewall grommet is in the right location.
sp53
Ok for sure it is correct now that I see the larger photo, and it looks like a better way than I did it. The only thing I see problematic is the grommet fitting. I fought mine having the grommet in first--- then using a funnel through the grommet to stretch the grommet out on the inside and fitting the wires from the inside of car out.
Good look you will get it
DavidApp
My Kit TR3 came with a brand new harness and as I was adding an alternator I undid the harness and added heavier wires also remove the generator wires. It was a pain to get the grommet through the bulk head. As far as I remember dish soap is your friend.
David
nichola TR6 Question on new wiring harness Triumph 6
C MGA Wiring harness question MG 7
Griz Rear Wiring Harness Question Austin Healey 6
B Question on OD wiring harness 57 Smallmouth Triumph 15
B wiring harness question: Triumph 3
Tinkerman TR2/3/3A Wiring Harness Question on my TR3A Triumph 8
Bone wiring harness question` Spridgets 1
bighealeysource BJ8 wiring harness question Austin Healey 8
M MGB 1970 MGB roadster wiring harness question MG 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
S Wiring Harness Replacement Spridgets 1
B TR4/4A Wiring Harness Triumph 6
Healey Nut Wiring Harness Routing Austin Healey 5
J Wiring Harness Austin Healey 5
R TR2/3/3A Replace wiring harness in steering column Triumph 61
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
R TR2/3/3A Install new wiring harness in steering column Triumph 16
nichola TR6 Victoria British wiring harness for TR6 Triumph 6
C For Sale MGA wiring harness MG Classifieds 3
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
R TR2/3/3A Installing wiring harness in steering column Triumph 59
BoyRacer How to clean a cloth wiring harness Austin Healey 14
S TR2/3/3A installing the wiring harness Triumph 8
A Spitfire BMCNE -Tech Session Custom Wiring Harness Creation -Links to Album Triumph 2
W TR2/3/3A New wiring harness Triumph 8
T TR2/3/3A Wiring harness Triumph 3
D new wiring harness Austin Healey 15
D 62 tri-carb wiring harness Austin Healey 10
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
SherpaPilot Wiring Harness for XJ6 Jaguar 1
tr3guy TR2/3/3A New Wiring Harness Triumph 7
MisterB How to spin engine sans wiring harness? Austin Healey 3
Rut TR4/4A Wiring harness female bullet connectors Triumph 6
Marvin Gruber BJ8 wiring harness install Austin Healey 6
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Rut 73 Midget wiring harness Spridgets 0
K TR2/3/3A Wiring harness "wire gauge" sizes? Triumph 20
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
K TR2/3/3A Wiring Harness Triumph 9
Got_All_4 TR2/3/3A TR3 A wiring harness Triumph 17
B TR6 Reverse light wiring harness routing Triumph 4
J Protecting new wiring harness under car section-Use clear shrink tubing? Austin Healey 4
mt10flyer TR2/3/3A TR3 wiring harness Triumph 7
Rut Wanted, Bugeye wiring harness Spridgets 0
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Rut Bugeye wiring harness Spridgets 2
mt10flyer TR2/3/3A Winter Project-Wiring Harness Triumph 4
