A long time ago I purchased a short green plastic stick from VB for the installation of rubber seals. The stick cost was about $3 and it has been worth its weight in gold. I used it when I installed my grommets and while it wasn't easy, it got the job done.
I've had no problem with any grommets yet - strong fingers I suppose - have also wondered if dental floss would work as though you were installing a tiny windshield
Those grommets are tough - I got mine in without cutting. Some brute force and a lot of ignorance on my part helped. (Also a little dishwashing soap.) I also used a small screwdriver which helped but it could have easily slipped and did nasty things to the paint (there's the ignorance part).
