I resorted to the technique Dale used. I'm kind of surprised the suppliers haven't addressed this problem already. There have been posts about the installation problem for years.
A diagonal cut from top to bottom, on the side, as suggested by British_Recovery, is the way to go. With the help from some soapy water and a pair of pliers, I was able to "screw" it into the hole just as he said.
I did mine by using some stout string and plenty of lube, wind the string around the middle section pass it through the hole from the top and and pull down on it whilst trying to press the rubber in from the top and twist the rubber as you do it, seemed to work for me. I did have the seat out and was lying on my back with my feet dangling over the back of the cockpit.
