Thanks, I figured a helicoil would be the way to go, just got lazy and didn't want to remove the windshield. I may search a little longer and see if anyone makes a screw that can be cut to fit so I can retap the frame on the car.
Thanks, Rut
Most of the screws in mine were stripped, but I was avoiding repairs since I didn't really know what I was doing and figured it would be time consuming. At the suggestion of people on the forum I purchased a helicoil insert kit from the local NAPA auto store (they had to order what I wanted). I had never used a helicoil insert before, and I was very happy with the results. I did one side at a time so that I did not have to remove it, and my windshield is stronger than original with the inserts.
Kevin
Kevin, thanks for the reinforcement! I just got in and picked up a helicoil set on my way here. It looks very straight forward and I'll feel much better when I have more than 2 screws holding the windshield frame in! I got the full set with tap, tool, and helicoils for about $15. I'll report back after I finish.
Thanks, Rut
I took off the drivers side pillar and cleaned it up, drilled and tapped the mounting holes, used the supplied helicoil tool and inserted all 3. It took me 4 tries and 4 helicoils on the center hole because I wasn't holding my mouth right. I replaced the mounting screws with some stainless ones that match up ok, but don't have the exact contour as the pillar. I'll replace those when I find some. All in all a pretty simple task, but I did have to remove the pillar. I don't want to do that again until I have the car painted! Thanks for the tips!
Rut
