Will fixing Healey Shake negatively affect Resale?
BrettBBonner
My Healey will sometimes get the healey shake. It's disconcerting. The cure, I'm told, is to continuously weld the transmission opening on both sides and perhaps add bracing.
Will this negatively affect resale?
Will this eliminate a Concurs rating if I choose to restore to that level?
Michael Oritt
"Will this negatively affect resale?
Will this eliminate a Concurs rating if I choose to restore to that level?"
Fer sure--
Assuming your car is structurally sound, start with the wheels, then move to the driveshaft.
Michael Oritt
bighly
I assume what you refer to is AKA Scuttle Shake.
Are there any original owners on the forum that can attest to the abscence of this shake on a new off the lot Big Healey?
My plan of attack has been:
1>New rear suspension (leafs, shocks, bushings). Done
2>New Drive line mounting hardware (Motor, Transmission, transmission rear mount bushings). Done
2>New hubs all around (obtained but not installed)
-awaiting 3&4 below
3>Front end rebuild
-bushings, kingpins obtained
-awaiting shocks, springs funding :smile:
-requires one shock tower top replacement (obtained but awaiting welding plan)
4>New wheels (Awaiting 2, 3 & funding :smile:
5>Steering gearbox etc rebuild, bushings, ball joints (Probably done with 3 above) (more funding :smile:
6>U-joint renewal. Done last weekend.
My hope was that by doing all the above I would reduce Scuttle Shake or at least change the speed at which it occurs. I usually just live through (read accelerate) it and some times think about astronauts during re-entry.
What am I missing?
John Loftus
I eliminated the scuttle shake on my BJ7 last year by rebuilding the idler, installing new hubs with new bearings, new 60 spoke wheels, new tires, and balancing/truing by a shop that specialises in wire wheels (Valley Wire Wheel in LA region). King pins and steering box are also in good shape.
Cheers, John
John Turney
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by bighly:
What am I missing?<hr></blockquote>
Make sure you balance/true the wheels/tires, brake drums/discs and driveshaft.
John, BN4
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
steveg TR6 Fixing the intake manifold Triumph 8
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Got_All_4 TR6 Is this head toast or worth fixing Triumph 3
S TR4/4A Fixing dash support Triumph 11
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
M BJ7 back panel fixing method Austin Healey 5
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
Jeepster Seat belt fixing Austin Healey 4
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
JamesWilson Fixing Fiberglass Flaws?? Restoration & Tools 9
T ideas on fixing - one carb keeps "rusting" Triumph 4
Hap Waldrop TR6 Fixing a TR6 engine Triumph 6
T Tips for locating/fixing foam rings under gas tank Triumph 4
T Ideas on fixing this? Triumph 19
regularman Found one problem while fixing another Spridgets 9
B Fixing crack in rubber bumper MG 1
bcliff Fixing a bad spot in the paint MG 3
germanmichel Fixing outer tube in steering box Austin Healey 11
G I my engine fixing to blow........................ Triumph 9
glemon "Fixing" Zenith Stromberg Emission Control Carbs MG 4
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
roscoe I'm fixing my overdrive with a saws-all Austin Healey 10
jhorton3 Fixing Things Spridgets 27
drooartz Leaking hubs, parts for fixing Spridgets 11
T Fixing Rust Triumph 16
bluemiata90 Fixing turn signals at head Triumph 3
69MGC Any tips for fixing a bent boot lid MG 7
cjm lightened flywheel,best fixing? Triumph 3
sparkydave Fixing Zenith-Stromberg needle adjuster Spridgets 5
S Fixing Dime sized chip Triumph 3
M Wedge tr7 turn signal switch fixing? Triumph 1
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
